My week in the workshop
Home › Forums › The Tea Room › My week in the workshop
  • #434772
    Phil Whitley
      @philwhitley94135
      Default More garage projects to see!
      Hi all, I have just put up this weeks look at present and future projects in my garage/workshop, hope you enjoy it, sorry about the black face, and thanks for all the likes and subscriptions I have recieved, if you like what you see, you could subscribe too!
      Thank you all!
      Phil,
      East Yorkshire
      UK
      #35652
      Phil Whitley
        @philwhitley94135
        and a more in depth look at some of my projects.
        #434774
        Ian Johnson 1
          @ianjohnson1
          Hi Phil just had a watch of your video, nice one! That's a good size workshop I'll definitely look out for your future projects and video's. I like the rescued valve grinder, never know when it might come in handy. And if I ever get myself sorted out with Youtube I'll subscribe.
          Ian
          #434786
          Grizzly bear
            @grizzlybear
            Thank you, very interesting.
            I like your grass cutter.
            Bear..
            #435214
            Phil Whitley
              @philwhitley94135
              Thanks for the comments chaps! Very kind words.
              Ian, I have had a thought about the valve grinder! It is limited by the size of the bore in the valve collet chuck, but it might be used to grind drills and small centres, though I think you would have to use the side of the wheel, You can of course remove the whole collet and motor assembly and substitute some other work holding attachment, still thinking!
              Bear, The Toro wheelhorse is a cracking good garden tractor, it has a proper cast iron transmission/gearcase with 6 speeds and hi/lo box, and was usually powered by a 14hp single cylinder Kohler engine, which was deafening, and had all the finesse of a large cement mixer, and used to snap conrods almost annually! the 2CV engine boosts the power from 14 banging vibrating hp to 29 smooth quiet hp, which proved to be far too much for the clutch, also a Kohler item, I will video the finishing when I get to it, but it will be using jockey pulleys to tension the V belt rather than the clutch to drive the cutter deck. The transmission drive already works this way, and never gave problems. I would have loved to have the cylindersw sticking out either side of the bonnet, but it was just too complex for the transmission, and my limited facilities when I put the engine in. Spot the Dexion?
              Phil.
