ML7 Main Bearing Oilers
Home › Forums › Beginners questions › ML7 Main Bearing Oilers
  • #8346
    Andrew Tinsley
      @andrewtinsley63637
      #262324
      Andrew Tinsley
        @andrewtinsley63637
        Hello,
        This has probably been done to death. However I am rescuing my ML7 and restoring it. It has broken oilers, so they need replacing. I remember that most people opted for the OEM oilers which I believe are still available?
        I seem to remember that someone advocated those available from ARC Trading. There is a considerable saving going this route, so are the ARC oilers good for purpose. I know that a lot of cheap oilers have problems setting up the flow rate.
        Thanks in advance,
        Andrew.
        #262349
        Ths
          @ths
          Recently, I replaced the rear (gear) end oiler on my ml7, as it had a cracked plastic bowl, and leaked everywhere. I found a flip top Adams oiler on eBay.au and bought it. Adams are still around, and made (I believe) the original oilers for Myford. They may be in Coventry. Expensive new, but still there, and it works as it should. 1/8 BSP. Hugh.
          Edited By Ths on 22/10/2016 13:47:51
