Miniature Steam Locomotive Management
Home › Forums › Help and Assistance! (Offered or Wanted) › Miniature Steam Locomotive Management
  • #263968
    Peter Wilson 14
      @peterwilson14
      Good afternoon,
      I wonder if Chris or Steve Addy could contact me concerning the article titled "Miniature Steam Locomotive Management" ?
      Thank you
      Best regards
      Peter W
      #32824
      Peter Wilson 14
        @peterwilson14
        #292410
        nipper
          @nipper
          Good Morning Peter. I have read your post and it was well done but I have a couple of comments. The reversing lever does not alter the piston travel only the valve travel but of course you knew this and it's a pity it passed the edit. The other, more pertinent issue is about charcoal briquets . I and another member of my club used them and while they got the fire started they clogged up the grate and ashpan, due to the excessive amount of ash, so that the fire went out once coal was added and it could not be recovered. Lump wood is a much better option. Best regards David Murray Staines SME
          #292494
          Bazyle
            @bazyle
            Easier than charcoal is a lump of plain wood from a skip cut to 1/4 inch shorter than the firebox, then split into thin strips before soaking in paraffin. This is easier to put into the firebox and you know it is going all the way to the back. The last piece is left sticking out to light before pushing home.
            At the end of the day once pressure is down don't forget to open the blower to prevent a vacuum forming in the boiler and sucking water in from the tanks if you haven't emptied them
            #292716
            nipper
              @nipper
              Hi Bazyle. Thanks for the reply but I have been driving engines since 1968 so while I felt obliged to warn people about charcoal briquets I do not need advise on how to run them myself. As for water in the tanks , always drain them is my advise.
              #292719
              julian atkins
                @julianatkins58923
                Apologies, but I am getting a little confused here!
                Is 'Nipper' Steve Addy of the aforementioned ME article? Or is 'Nipper' someone else?
                Cheers,
                Julian
                #292752
                nipper
                  @nipper
                  Hi Julian. Thanks for the note, I am David Murray of Staines SME. I am sorry if I seems a bit sharp in my reply but the purpose of my comment was to warn other people of the pitfalls of using charcoal briquets not start a forum on advising me on how to start a locomotive. Thanks anyway.
                  #292754
                  Nick_G
                    @nick_g
                    Posted by nipper on 10/04/2017 09:56:28:
                    Fill it with diesel, turn the key and press the button. ………. 'innit' ??? laugh
                    Nick winkwink
                    #293262
                    nipper
                      @nipper
                      Hi Nick. This my last post on this subject. My best friends father was an engine driver, many years after he retired I asked which was his best day as a driver. ' The day the diesels arrived' Nuff said.
                      #312981
                      Phil Barber
                        @philbarber30745
                        Good article, as a newcomer, appreciated.
                        #530333
                        Paul Sherriff
                          @paulsherriff40313
                          After running and then blowing down, what is good practice to prevent rusting up of cast iron cylinder blocks
                          i run the engine up and down a few feet relying on the lubricator to pump some oil into the cylinders but I sometimes feel this is not enough
                          Previously I have run locos that have gunmetal cylinders and this has never been a worry
                          Thanks
