Mini Lathe Delivery -NOT
Home › Forums › The Tea Room › Mini Lathe Delivery -NOT
  • #833846
      I thought you may enjoy seeing this little vari-speed Chinese Taiwanese lathe being delivered, uncrated and positioned.
      #833850
      Peter Cook 6
        @petercook6
        Now that’s a proper lathe!! Trouble is you seem to need to be a Jolly Green Giant to actually reach things. I look forward to seeing what sort of things he will be machining on it.
        PS is it Chinese or Australian?
        #833853
          Grizzly bear
            @grizzlybear
            Thanks Jason.
            Really interesting and educational.
            Bear..
            #833911
            Nigel Graham 2
              @nigelgraham2
              Thankyou Jason!
              You have to admire the skill of the Scotts crew, manipulating a massive lump of very serious money in confined areas. That must have taken quite a bit of planning.
              Not a safety-helmet in sight… that would have my crane slinging and operating instructor tut-tutting.
              I wonder too how the manufacturers put it in the container, with so little room to spare. The slightest twist would have jammed the skid frame against the wall.
              On the lathe itself I like the quill-type tailstock and I am only surprised that was not very common as standard on centre-lathes. They were on capstan-lathes although there the tailstock could be used as at least as much as the saddle on some parts being made. Though on a small machine without the luxury of tailstock body length, a quill handwheel could be in the way when everything is all a bit closed up together.
              The works manager as I assumed he is, commented on the location of the DRO. It is a bit odd, putting it beyond the work-piece, although you’d not normally be setting that when the machine is running, be it on a huge great lathe like that or a modest Myford 7.
              I think I understood aright that the basic spindle motor controls are duplicated on the saddle. Necessary on a lathe of this scale.
              I noted it came as standard with a 4-way tool-post though CEE had ordered the QCTP option as well. Although looking at the size of the tool-blocks, the turner himself might not be so “quick” at changing them around after a couple of hours or so of it.
              I had a little chuckle at the oil-can: I’ve one of them on my EW lathe’s bench. So if it’s good enough for CEE….
              #834113
              larry phelan 1
                @larryphelan1
                Must have been a good trick getting that thing into the container !
                Just wondering, why did they put that bar into the chuck before unloading ?
                #834121
                Nigel Graham 2
                  @nigelgraham2
                  The bar was used with a sling for extra control against yawing.
                  I took the point that the large-bore version is drastically more expensive, perhaps to special order, but I was surprised how small is the spindle bore for the overall size of the machine. The chap held the centre bush in his hand, showing us the scale of it. (Oh, how do you eject the centre on a lathe that big?)
                  Lathes on this scale and above are not new of course. Those made for producing the pre-1950s warship gun barrels, up to about 90 feet long, for example. Some of those even had two saddles, fitted with steps on which the turners stood, riding with them.
                  While quite early in the 19C, there existed special faceplate lathes for discs like flywheels and very large cylinder covers. No bed and tailstock but instead a cast-iron floor carrying a table with the cross- and top- slides. The engraving of one I saw, suggested the floor had slots or a matrix of holes for the basic positioning of the table, in front of a faceplate some ten or twelve feet diameter.
                  #834127
                  peak4
                    @peak4
                    #834129
                    peak4
                      @peak4
                      Addendum to the above, rather than trying to edit the post;
                      Here’s one with four toolposts
                      https://www.sheffieldhistory.co.uk/forums/topic/8535-types-of-lathes-used-during-war/
                      image_2026-01-25_120221281
                      There’s all sorts of interesting stuff on the Sheffield History forum; e.g. do a search on lathe
                      https://www.sheffieldhistory.co.uk/forums/topic/19076-a-naval-gun-in-the-making
                      #834136
                      John Haine
                        @johnhaine32865
                        I had a holiday job at AEI in Rugby. The path to the canteen took one past a humongous lathe used to turn turbine and alternator shafts.
                        Also GEC had their turboalternator plant in Rugby. One school history lesson was enlivened by a huge bang caused by a set on test seizing up and exploding. School must have been 4 miles from the factory.
                        #834143
                        cedric 1
                          @cedric
                          #834149
                          cedric 1
                            @cedric
                            #834152
                            Zan
                              @zan
                              Impressive. I wonder about the cost.
                              Then what about the machine which made the bed?  Now that must be seriously big!!!
                              Just imagine the moving of the Sheffield lathe without the modern  mobile crane.
                              #834161
                                The bar is not to stop Yaw
                                It is there to stop the top heavt head from heading towards the floor, if it were to start falling front or back teh bar being between the slings would limit how far it can go.
                                #834165
                                  He makes a lot of use of the steadies and also revolving tailstock chucks. As he says if he was wanting to face say a 5m long tube he would need to find a way to support the 4m plus that would be sticking out the left hand end of the headstock. Not a problem with the steady.
                                  #834176
                                  Robert Atkinson 2
                                    @robertatkinson2
                                    I was more impressed by the mobile crane than the lathe. The lathe looks quite basic.
                                    Interesting to see him pouring 68 viscosity hydraulic oil into a tank marked to use 32 or 46… (42:30 mark).
                                    Then there is the 380V 3 phase power for the hydraulic pump on a MALE connector on the lathe. That one certainly does not meet C-Tick! Positively lethal.
                                    Robert.
                                    #834178
                                    Bill Phinn
                                      @billphinn90025
                                      #834210
                                      Robert Atkinson 2
                                        @robertatkinson2
                                        I doubt it. The oil viscosity is specified at well above ambient.
                                        #834311
                                        simondavies3
                                          @simondavies3
                                          #834321
                                          Swarf Maker
                                            @swarfmaker85383
                                            I think that one of the first things that Kurtis will be doing is modifying those fixed steadies.  As supplied they appear to have a solid frame and since the large cylinders that he works on have to be lowered onto the lathe with a crane, threading those on will be a big issue!
                                            #834332
                                              I think they may be a “U” shaped design where the top bar lifts out rather than his other centrally split & hinged ones. You can see some big nuts at the top of the U and what may be a hinged bridle joint.
                                              steady
                                              #834343
                                              Swarf Maker
                                                @swarfmaker85383
                                                Well observed Jason.  As the paint looked contiguous around the frame and no parting lines were visible I made that observation, somewhat foolishly, in disbelief!  From your still frame image, there is a black rod/handle sticking out from the triangular reinforcement on just one side, so perhaps a hinge on the other side?  No doubt the next CEE video will reveal all.
