Low-medium strength penetrating/wicking threadlocker
Home › Forums › General Questions › Low-medium strength penetrating/wicking threadlocker
Viewing 21 posts - 1 through 21 (of 21 total)
  • #827020
    michael howarth 1
      @michaelhowarth1
      May I once again draw  on the knowledge of the Forum in my search for a low to medium strength penetrating (wicking) threadlocker. I understand that Loctite 220 would fit the bill but I cannot find a UK stockist. I already have Loctite 290 (penetrating) but it is medium to high strength and a mite too powerful for 6BA/8BA grub screws. Bondloc also do a 290 med/high strength penetrating but not as fae as I can establish a lower strength variety. Any recommendations will be appreciated.
      Mick
      #827024
        Silmid.  Scary expensive though – £36 for 10ml!
          Wink Hackman
            @winkhackman25989
            You could try this:
            Superloc 355
            #827052
            Kiwi Bloke
              @kiwibloke62605
              It depends on how strong you need the ‘locking’ to be – and you won’t know how strong your chosen stuff will be, without experiment. You could consider shellac (dissolved in alcohol). Old-fashioned, but it works, you can tailor its viscosity to your preference, and it’s cheap…
              #827072
              bernard towers
                @bernardtowers37738
                Cant get my head round the 1/4″ limit Michael?
                #827079
                  It’s not a ‘limit’ as such, Bernard … Simply the manufacturer’s recommendation
                  Stronger grades are more suited to fasteners over 1/4”
                  michael howarth 1
                    @michaelhowarth1
                    Just to put you more in the picture, I am looking to secure the fasteners in the valve gear and motion work of a Gauge 1 Loco. The fasteners are either 8BA or 10BA. The chassis is running beautifully on air at the moment (pausing to touch wood) and I would like to keep it that way without dismantling and applying threadlocker. I have used Loctite 290, wicking grade in the past but it is mighty strong when set and I have had casualties in the past when dismantling. Loctite 220 seems as if it would fit the bill as a low/medium strength penetrating adhesive but I cannot track down a UK stockist. (Henkel, the maker, who used to be such an obliging and helpful company have cut me off twice on the telephone). Truloc and Bondloc do not appear to offer a penetrating grade.
                    I am quite drawn to Kiwi Bloke’s suggestion and I am guessing that diluted nail varnish might achieve the same end. Thanks for the contributions so far.
                    Mick
                    #827103
                      On michael howarth 1 Said:
                      … but I cannot track down a UK stockist….
                      Mick
                      Mick, can you see my post #827024?  First answer in the thread and it identifies a UK supplier. You may have missed it because a forum bug causes posts to disappear and reappear.
                      It said:  Silmid.  Scary expensive though – £36 for 10ml!
                      I’ve no idea how well it works, but 220 is designed for your purpose.  The alternatives are pot-luck;  great if they work, rubbish if they don’t.  When getting it right is important, I cough up for the real thing.  If failure is acceptable, then by all means try diluted nail varnish!
                      michael howarth 1
                        @michaelhowarth1
                        Hallo Dave. Thanks for your post. Yes, the price is a bit scary. And p&p is £25. Just a wee bit over the top for 10ml methinks.
                        mick
                        #829861
                        lalan45
                          @lalan45
                          I’ve been down this road too — you’re right that 290 can be a bit overkill on the smaller screws. In the UK, a few folks have had good luck with Loctite 222 (low strength) for things like 6BA/8BA, and 222MS if you want the medium‑strength variant that still breaks free more easily than 290. Another option is Permatex Low Strength Threadlocker — not as commonly stocked here but sometimes easier to find through online retailers. Also worth checking specialist fastener suppliers rather than big DIY stores; they often carry a wider range of the weaker formulas. Hope that helps
                          #829912
                          michael howarth 1
                            @michaelhowarth1
                            Thanks for that Lalan. I have got Loctite 222 but it is not a wicking grade. Can it be effectively diluted I wonder.
                            Mick
                            #829945
                            cedric 1
                              @cedric
                              Yes shellac is what we used before loctite came along. It works well on small screws, just a dab.
                              But shellac was hideously expensive last time I saw some in a hardware shop. A possible substitute is Aviation Form-A-Gasket hard setting variety.
                              #829955
                              Grindstone Cowboy
                                @grindstonecowboy
                                Nail varnish can be useful as a low-strength threadlocker too.
                                Rob
                                #829960
                                  On cedric 1 Said:
                                  But shellac was hideously expensive last time I saw some in a hardware shop. […]
                                  Shellac flakes are quite reasonably priced on Ali Express
                                  Robert Atkinson 2
                                    @robertatkinson2
                                    On aircraft instruments we used a clear red lacquer for locking and indicating screws had been tightened. It was often called “glyptal” but that is a opaque paint used for insulation. Available in small bottles on ebay and the like “Alclad Transparent Red Lacquer” looks very similar.
                                    Robert
                                    #830012
                                    cedric 1
                                      @cedric
                                      Thanks much for the tip. I have been seeking some to make my own marking-out blue. The commercial layout blue, Dykem etc, seems to be only available in spray cans at even more hideous prices these days. And I do prefer the less messy brush on option.
                                      #830017
                                      renardiere7
                                        @renardiere7
                                        Cedric, I saw someone advertising refillable broad tip marker pens specifically for Dykem along with refill bottles. It may have been one of the knife maker suppliers, I’ll have a look.
                                        #830019
                                        renardiere7
                                          @renardiere7
                                          #830021
                                          Mark Easingwood
                                            @markeasingwood33578
                                            Walters & Walters sell Dykem.     LINK HERE
                                            Workshop Heaven sell shellac flakes, as do other woodwork related suppliers.   LINK HERE
                                            #830042
                                            peak4
                                              @peak4
                                              Edding 850 markers and similar work well enough for me
                                              https://www.edding.com/en-uk/products/edding-850-permanent-marker/
                                              and are refillable (with smaller refills than this available from eBay/Amazon etc.
                                              https://www.edding.com/en-uk/products/edding-t-1000-refill-ink-permanent-marker/
                                              Back to threadlock; I can’t find if the Sealey one is suitable for wicking;
                                              https://www.sealey.co.uk/low-strength-thread-lock-50ml-scs222s/
                                              It’s available from cheaper outlets, including Bearing Boys who may well be able to advise, though for some reason it features on a different page to this one;
                                              https://www.bearingboys.co.uk/Threadlocking-1074-c
                                              Bill
