Loctite
Loctite
Home › Forums › General Questions › Loctite
Viewing 25 posts - 1 through 25 (of 25 total)
  • #436951
    Watford
      @watford
      What in general is the shelf life of Loctite products? I have a twenty-year-old 50ml bottle of 601 which is about half full. Seems a shame to bin it at about forty quid a pop.
      #26954
      Watford
        @watford
        #436953
          There are many discussions about this on the forum … try the search box on the homepage
          My own understanding, based on direct advice from Hemel Hempstead is:
          For the anaerobic thread-lockers and retainers: If it is liquid in the bottle, it is still useable.
          RMA
            @rma
            I've used really old Loctite. Best way if you're not sure is to try it on some scrap.
            #436957
            Phil P
              @philp
              My bottle of 601 was given to me about 25 years ago, and it was of unknown age then.
              It still performs perfectly well every time I use it, and will probably get passed on to someone else when I am pushing up daisies. !!
              Phil
              #436970
              Martin Hamilton 1
                @martinhamilton1
                I spoke to Loctite about shelf life of Loctite a few years ago, each bottle is stamped with a use by date. The shelf life is 2 years from manufacturer date to the date stamped on the bottle, they told me that after the use by date they could not say the product would work as well as the specs state. I still use various Loctites from thread lockers to bearing fit & retainers that in some bottles i have are 10years old down to 3-4 years old & all seem to work for me fine, whether they hold as strong as a in date bottle i have no idea & all i can say is every job i have used the out of date stuff hasn't come apart.
                #436972
                old mart
                  @oldmart
                  I have had no problems using old Loctite, but if your application is critical, then a test would be a good idea. Loctite products are now made in China and can be bought for much less than £40 for 50ml. For most people a much smaller bottle would last for ages.
                  #437002
                    Posted by Martin Hamilton 1 on 12/11/2019 13:50:58:
                    I spoke to Loctite about shelf life of Loctite a few years ago, each bottle is stamped with a use by date. The shelf life is 2 years from manufacturer date to the date stamped on the bottle, they told me that after the use by date they could not say the product would work as well as the specs state. […]
                    So … would it be fair to deduce that whilst my 30+ year old 638 will probably last another five years or more; its new replacement might only last two ?
                    angel Clever so-and-sos these chemists [maybe]
                    P.S. … No, I haven’t done comparative testing on old and new
                    … and like you, I am happy with the results from old.
                    #437006
                    Watford
                      @watford
                      Thanks chaps smiley
                      Certainly will not throw the existing bottle away then. I think I will buy a very small 638, and out of interest run a couple of comparative tests.
                      It looks as if the 638 is a better/stronger product than 601 in any case so it might be horses for courses.
                      #437010
                        Would I use old Loctite in my workshop? Yes.
                        Would I fly on an aircraft I knew was maintained using old Loctite? No!!!
                        #437014
                        Robert Atkinson 2
                          @robertatkinson2
                          Did I religiously check the expiry dates on "consumables" when I was quality manager for an aerospace company – of course I did.
                          Did I then take it home a few days before it expired – well if I'd waited until it expired the company woyld have to pay to dispose of it as chemical wastedevil
                          Edited By Robert Atkinson 2 on 12/11/2019 18:21:40
                          #437020
                          old mart
                            @oldmart
                            Go on the Loctite website for the full information on the wide range. As far as I know, they have always had a shelf life of 2 years or less.
                            #437028
                              There are lots of reasons for 'shelf life' other than product degradation. These include making sure stock is used in rotation, making sure new formulations replace old ones, helping traceability.
                              For 'critical applications' the product will have been tested to ensure it still works at the end of its shelf life; this doesn't mean it ceases to work after two years and a day, just that it hasn't been tested for a longer shelf life so it can't be guaranteed to still work.
                              I note that a similar shelf life applies to medicines but experts are at pains to make clear that in an emergency an out-of date asthma inhaler is better than nothing at all (for example).
                              Martin Hamilton 1
                                @martinhamilton1
                                There are obviously industries like aviation/ aerospace + others where in date Loctite would be specified to be a must, for the rest of us it probably dose not apply or matter that much. The problem also with the 2y timeline is when you buy Loctite from a suppliers they sometimes have had it sat on there shelf for some time, when i buy from a local suppliers i always look at the date stamp on the bottle. Most times there is usually around 12-18 months left on the date stamp, if i am buying online i will ask first the expiry date as some have only had a few months left on them & look elsewhere on line for longer date stamps. I figure if i am paying the same price then i might as well have longer in date Loctite even knowing i will still be using the product well beyond the use by dates.
                                #437030
                                Howard Lewis
                                  @howardlewis46836
                                  I was told that as long as the Loctite was still fluid, it was useable.
                                  I have used Loctite (in large bottles) WAY past the "best by" date. It was so effective that when trying to separate the two parts with a copper mallet, I eventually stopped, for fear of doing damage!
                                  The Loctite that I use, currently is decades old, but is still pretty effective. Most of the time the shop, although well insulated, is unheated (only while I am in there, or very slightly if prolonged frost is forecast)
                                  It works for me, but may not for you.
                                  #437039
                                  Clive Foster
                                    @clivefoster55965
                                    Most of us don't have any sort of feel for just how strong a loctite bond between adequately prepared materials is.
                                    The actual strength is related to the area of the bond and, in lesser degree, its thickness. Most jobs folk like us use it for don't require anything like the full specified strength to function perfectly adequately. Particularly when considering the stronger types even half the specified strength is likely to be plenty for us. The bond areas involved in thread locking or fitting a shaft or bearing are quite large,
                                    Frankly for the casual uses it's preparation quality that is likely to cause issues not the loctite. Whether factory fresh or seriously over aged.
                                    Adhesive tapes are a good illustration of the effects of bond area on joint strength. The actual stickum isn't huge but given a decent area the joint is very strong. The weakness is in peel where you can concentrate a lot of force at the end of the joint line and effectively roll it up. If things can't be peeled up, generally the case with things we use loctite for, the joint remains intrinsically very strong.
                                    #437043
                                      Posted by old mart on 12/11/2019 19:01:13:
                                      When I was at BAe it was our QA that applied a 'Shelf Life'
                                      … The Loctite bottles from Hemel Hempstead were not so marked.
                                      Well-reasoned comments [above] seconded !
                                      Mark Rand
                                        @markrand96270
                                        I have seen it quoted that Loctite did not apply a shelf life to their products until a large customer in the Aerospace industry required them as part of their quality controls…
                                        #437143
                                          Posted by Mark Rand on 13/11/2019 16:53:13:
                                          At which point they probably spotted an opportunity devil
                                          Ron Laden
                                            @ronladen17547
                                            I think we can take it that Loctite is like a good wine or cheese it matures with age…wink
                                            #437184
                                            mark costello 1
                                              @markcostello1
                                              My eye Doctor uses clear nail polish with good results, and holds with less torque to disassemble. Could color coordinate if needed.
                                              #437185
                                              not done it yet
                                                @notdoneityet
                                                I have a small bottle (much depleted) from 40 years ago. Likely a different chemistry, but still works for what it was bought for all that time ago – a simple thread-locker (for engine big end bolts).
                                                Some truloc versions have not lasted as long, but as they were not purchased by me I don’t know their history.
                                                #437203
                                                Graham Stoppani
                                                  @grahamstoppani46499
                                                  I used to be the MD of a company supplying chemistry to the aerospace industry amongst others. As it happens we were also a subsidiary of Henkel (who own the Loctite brand) for a while. All our products were supplied with 'use by' dates not because they would degrade over time but because it was a requirement of our customers.
                                                  The storage environment is the biggest variable in shelf life. One of our products was just a mixture of two salts, when asked for a use by date by one customer we tried to explain that in a damp warehouse one or two days at most but in a dry warehouse we could put as many millennia as they wanted! Another important variable is exposure to UV rays and the embrittlement of plastics. Likewise, some products will embrittle plastic over a period of time – HP sauce being a good example. That is why most sauce bottles have around five layers of different plastic in them.
                                                  In the end we settled for a standard two year shelf life as that was what our customers wanted. Nice little earner for us as we would then charge to take back out of date product from the customer, re validate it and sell it back to them. Deep joy.
                                                  #437207
                                                  Russell Eberhardt
                                                    @russelleberhardt48058
                                                    For me, the shelf life is determined by the state of the outside of the bottles. No matter how careful I am, the outside of each bottle gradually builds up a sticky residue that is almost impossible to remove with solvents but gets all over my fingers!
                                                    Russell
                                                    #437219
                                                    Watford
                                                      @watford
                                                      Posted by Russell Eberhardt on 14/11/2019 08:55:25:
                                                      Russell
                                                      Russell, I have found that the solvent/cleaner used by double glazing fitters does a fair job of this. A useful product to have in the workshop, though care is needed on some delicate surfaces. Obtainable from those factors who supply double glazing firms.
