Leaf springs
Leaf springs
Home › Forums › General Questions › Leaf springs
  • #97717
    The Merry Miller
      @themerrymiller
      Well I'm goin to stir up a hornets nest now, I think)
      We are hearing a lot just lately about the length of Paralympic athlete blades like Oscar uses.
      Nobody seems to mention the characteristics of the leaf springs which could possibly vary considerably and thus give some athletes more of an advantage than the length of the springs.
      I don't know if there are standards for blade deflections etc that they all have to conform to but the speed and bounce that some of these athletes have aquired when sailing through the field makes the mind boggle.
      Look at the Brit in the 200m, Richard Whitehead, they way he sailed through the field on his blades defied belief.
      Comments please on leafspring characteristics would be welcome!!
      Len. P.
      #22200
      The Merry Miller
        @themerrymiller
        #97720
        Sub Mandrel
          @submandrel
          I imagine they are very carefully tuned, they have to match the athlete's rhythm. The fact Oscar P's performance was Olympic final, but not a medal suggests to me they are pretty fair. I would have no problems with an 'open' class.
          I thought the 'catchup' of the guy who beat Oscar yesterday in the 200 accused of having blades that were 'too long' is reminiscent of Ussain Bolt being 'too tall' to sprint. Apparently Oscar has to have 'Olympic approved' blades which are shorter than 'Paralympic' ones, so he's not complaining about cheating, but unfairness.
          Perhaps narrow carbon fibre blades would be good for suspension.
          Gray62
            @gray62
            What has this to do with ME???
            Totally off topic. Let;s not bring politics etc into this arena!!!!!
            #97728
            Clive Hartland
              @clivehartland94829
              Have you ever seen a Carbon Fibre fishing rod explode? Though they are excellent and springy for fishing , if they come under extreme load they shatter and break into shards.
              With regard to the athletes, I think it is amazing that they have been able to get off the wheelchairs or false legs and run in a race.
              There is no two ways about it, it is just a race and there should be no moaning about blade length and if you lose start training with longer blades.
              Recently there were TV pictures of an 'Able' man who was running and leaping about with blades, my first thought was that it is a long way to fall if you stumble ! It must be very tiring with them on.
              #97730
              KWIL
                @kwil
                The ME question is, can we use carbon fibre "blades" as leaf spring replacements in our model world?
                #97731
                julian atkins
                  @julianatkins58923
                  i use old eclipse hacksaw blades ground to the appropriate width for miniature loco springs. not sure i would want the 'bounce' with carbon fibre type blade material!
                  cheers,
                  julian
                  #97787
                    Posted by KWIL on 03/09/2012 22:50:57:
                    Can't see any technical reason why not, although it is rather expensive
                    … Look here for stock sheets.
                    More serious stuff is "Filament Wound" to put the strength/stiffness where it is needed. At the other end of the range: "Pultrusions" need to be used carefully; because these have all the filaments running in the same direction.
                    If you want a "tough" version, go for Carbon Kevlar mix [although ready-made sheet does seem difficult to find]
                    Edited By Michael Gilligan on 04/09/2012 23:39:08
                    Edited By Michael Gilligan on 05/09/2012 00:08:22
                    #97796
                    Ian S C
                      @iansc
                      My nephew has been most of his working life, building luxuary super yatchs, latterly from carbon fibre, etc,not too long ago they got an autoclave for cooking hulls and masts, that cost a million or two. Ian S C
                      #97826
                      Sub Mandrel
                        @submandrel
                        Carbon fibre fishing rods take quite a bit of punishment – at least the beachcasters do.
