Jaws in the chuck
Jaws in the chuck
Home › Forums › General Questions › Jaws in the chuck
  • #451935
    Steviegtr
      @steviegtr
      I went to fit a 2" bsp plug into the 3 jaw today & it was too big so I took out the jaws to reverse them. They would not fit. I had a look at them & realised the thread cut was the other way round so would not fit.
      I then remembered when I bought the lathe , there were other sets with it. Of course the correct ones were in the box. So fitted them. Beginners mistake I guess.
      Also looking at the pictures which way is the best . I plunged for the jaws in so there was no rotating jaws sticking out. Is this correct. Also yes I did give the jaws a dam good clean. This part is having a 9 1/16" hole down the centre & then a taper cut down it to self centre coins in the punch I am making. 316 Stainless & machines very well.
      #27138
      Steviegtr
        @steviegtr
        #451937
        Paul Kemp
          @paulkemp46892
          Steve,
          Second picture with the jaws in is the best for the reason you stated (safer) and also because more of the scroll is in contact so less likely to damage the chuck if you horse it up.
          Paul.
          #451942
          Steviegtr
            @steviegtr
            Ah thanks for that. Feel silly asking these questions. But I guess I only have to ask once.
            Steve.
            #451943
            Anonymous
              While most 3-jaw chucks have two sets of jaws, small precision 3-jaw chucks for use on instrument lathes normally only have one set. which are reversible. The 'threads' on the rear of the jaws are like a very flat ellipse.
              #451946
              Clive Brown 1
                @clivebrown1
                If the 9/16" hole is through-drilled, there could be a risk of hitting the chuck jaws if they are as shown in photo no. 2. Best to check.
                #451952
                Steviegtr
                  @steviegtr
                  Posted by Clive Brown 1 on 12/02/2020 23:05:46:
                  I checked that & have already drilled to 10mm . There is enough room. I am only just poking the drill through the end & then returning to be sure. Thanks for that.
                  Steve.
                  #451955
                  Paul Kemp
                    @paulkemp46892
                    3 step jaws, he is on middle step so a step worth of clearance behind at 9/16" should be plenty of room. When it's spinning you should be able to see the drill breaking through.
                    Paul.
                    #451960
                    ega
                      @ega
                      Posted by Paul Kemp on 12/02/2020 22:28:58:
                      Steve,
                      Paul.
                      Isn't there a trade-off between depth of engagement with the scroll and the distance between the work and the face of the chuck? Neither setting is ideal in my opinion.
                      The chuck is apparently a Grip Tru and if it is in good condition it would be a shame to overtighten it.
                      #451961
                      Steviegtr
                        @steviegtr
                        Posted by Paul Kemp on 12/02/2020 23:45:43:
                        Paul.
                        Yes I can see behind it.
                        Steve.
                        #451962
                        Steviegtr
                          @steviegtr
                          Posted by ega on 13/02/2020 00:30:22:
                          Steve,
                          Paul.
                          The chuck is a Pratt & something. Yes I would have liked the work to be flat against the chuck face ideally. I checked the true with a digital dial gauge & it was slightly out. I refaced it & centre drilled & all seems pretty good so far. Lesson learned was not to remove the work until all operations finished. Once I have the hole to the correct size for the 9 1/6" fly press punches, I will start to turn the taper. I have watched the Geordie guy on you tube tonight he is called double boost & has a lathe with a chuck heavier than my lathe, & he turned the taper with a boring bar the wrong way round from the back of the job. Why is that. Does anyone know. Or is it just so you can see better.
                          Steve.
                          #451964
                          Martin Connelly
                            @martinconnelly55370
                            Depending on the taper it may have made it easier to set the topslide over to cut the far side of the taper than the nearside. At some angles you can have issues with handles interfering with each other or even knuckles hitting things. The position may just have made it easier to turn the handle evenly for a better finish, straight wrist compared to bent wrist comes to mind. I have not seen the video so am just speculating.
                            One other thing is that the pressure on the topslide leadscrew, nut etc, will be in the same direction as a conventional external cut. There may be a reason he wanted this to be the case.
                            Martin C
                            #451966
                            Steviegtr
                              @steviegtr
                              I see what you mean. But I thought it was always best to have a downward pressure on the slides. The way he did it means the pressure is trying to pull the cross slide upward. Or am I missing something. Later today if I ever get up I plan to attack the taper. I will be doing it from the front of the work. I have not even worked out the angle I need yet.
                              Steve.
                              #451986
                              Brian H
                                @brianh50089
                                Could it be that the 'Geordie guy' was running the lathe in reverse? That way the pressure on the cross slide would still be downward.
                                Sometimes (screwcutting for example in a blind hole) this is better because the tool is moving out of the hole with no chance of running the tool into the job.
                                #451989
                                Paul Kemp
                                  @paulkemp46892
                                  Posted by Steviegtr on 13/02/2020 00:40:39:
                                  Steve,
                                  Paul.
                                  Steve.
                                  Steve,
                                  One reason for the way he did the internal taper may be he was trying to get a matching taper – turned the male taper first and then wanted to do the female at the same setting? Saves a lot of faffing around resetting the compound to pick up the correct angle again!
                                  ega,
                                  As to what is ideal, that is a matter of opinion. If you feel so, perhaps you can share the benefit of your experience and tell us a better way? In my limited 40 odd years of experience the best way to do an awkward job is the one that works and gets it done. There are many compromises that have to be made when deciding on a method of work holding, not least the size of the machine and the available kit.
                                  Paul.
                                  #452018
                                  Steviegtr
                                    @steviegtr
                                    Turning an inside taper
                                    This is the taper turning from the rear side. ?????
                                    Skip the 1st few minutes.
                                    Steve.
                                    Edited By Steviegtr on 13/02/2020 12:31:19
                                    #452022
                                    Martin Connelly
                                      Paul got it correct, he cut the external taper first and left the cross slide at the angle used (he says so in the video).
                                      Martin C
                                      #452065
                                      Steviegtr
                                        @steviegtr
                                        Ah I see said the blind man, to his deaf daughter. Thanks for that. I thought it was so the video could be seen. Umph.
                                        Steve.
