Identifying belt type for these pulleys please
Home › Forums › Help and Assistance! (Offered or Wanted) › Identifying belt type for these pulleys please
  • #307791
    Nige
      @nige81730
      My ML4 currently has a leather and steel link type belt on it but as i want to move the layshaft back a bit I will need a new belt. The first photo below shows the layshaft pulleys. They are about 1/2 inch wide at the outside edge and about 1/4 inch at the bottom.
      The photo below is of the driven pulleys on the mandrel. They are very similar to the layshaft pulley with the dimensions being only very slightly smaller than those on the layshaft.
      I would like to know what section vee belt I need please. I think it is called A section ? If anybody has recommendations for a suitable adjustable linked type belt that would be useful thank you.
      #33031
      Nige
        @nige81730
        #307798
        HughE
          @hughe
          Nige,
          Details for v belts can be found in Tubal Cain's ME Handbook section 13. The width at the top for A profile is given as 13.29mm.
          Hope that helps.
          Hugh
          #307799
          Nige
            @nige81730
            Thanks Hugh. my measurement of 'about 1/2 inch' is probably quite close but I will check more closely tomorrow.
            #307801
            John Haine
              @johnhaine32865
              Fenner Twist Link is good. I use it on my Super 7. You can get it from RS at a price but there may be other sources.
              Aha! Lathes.co.uk stock it:
              Actually I may have got mine from there. I use it both on my lathe and VM-B milling machine.
              #307804
              Meunier
                @meunier
                Re Fenner Twist Link or similar, has anybody had any success using it for replacing Tri-Leva belts on ML7 ?> Thanks
                DaveD
                #307811
                Robbo
                  @robbo
                  Probably 'A' section.
                  Have a look here – **LINK**
                  #307815
                  Nige
                    @nige81730
                    John Haine: Thanks I will measure up and give Tony at lathes.co.uk a call tomorrow.
                    Robbo: Thanks 😀
                    Edited By Nige on 18/07/2017 22:19:10
                    #307817
                    Nicholas Farr
                      @nicholasfarr14254
                      Hi Nige, some guidance on measuring pulleys can be found in this **LINK** and belt sizes can be found by using the R/H arrow.
                      Regards Nick.
                      #307818
                      V8Eng
                        @v8eng
                        Posted by Meunier on 18/07/2017 21:23:29:
                        DaveD
                        I do not think they would work on a Tri-Leva assembly, if I remember rightly you need a smooth outer surface on the back of each belt for the tensioning rollers to press against.
                        You could probably use a link belt on the drive from the motor to the idler (counter shaft?) pulley though.
                        Edited By V8Eng on 18/07/2017 23:09:16
                        #307910
                        Meunier
                          @meunier
                          V8Eng, double-drat, yes now you mention it – of course. Ah well, was hoping to avoid taking it all apart. Thanks
                          DaveD
