How do I drill this hole
Home › Forums › General Questions › How do I drill this hole
Viewing 13 posts - 26 through 38 (of 38 total)
  • #462368
    Mick B1
      @mickb1
      Posted by Old School on 04/04/2020 19:08:46:
      The ends cannot be skimmed up on the side you cannot see there is a bracket for part of the suspension also I don’t have a steady for the lathe. So a non starter.
      Its going in the mill
      Not fair!!!! cryingcryingwink
      Oh, go on – have it your way…. laugh
      Edited By Mick B1 on 04/04/2020 20:01:15
      #462372
      Former Member
        @formermember19781
        #462386
        old mart
          @oldmart
          Mill it is then, unfortunately. To get the piece mounted dead vertical is the first hurdle to cross. I would try to get hold of a block of aluminium, or two smaller blocks which could be milled for the ends of the casting to sit on. Maybe 2 blocks with holes for it to fit in. If the holes matched, the blocks could be attached to an angle plate and adjusted until the job was vertical.
          #462407
            If you are going to make a cradle to hold it that could just as easily be mounted on the lathe's cross slide as on an angle plate and would make it easier to pull the drill in and out to clear swarf as the carrage can be moved faster than raising the mills head.
            #462436
            Kiwi Bloke
              @kiwibloke62605
              The suspension brackets certainly limit your options. Pity, because Mick B1's suggested method was better than mine, I think. However the option of using the lathe as an horizontal borer remains. Surely a set-up on the boring table (cross slide) should be more rigid than a skyscraper on the milling table. There's so many ways to skin a cat…
              As Bill Chugg suggests, please could you post pix of your chosen set-up? You've got us on tenterhooks.
              Edited By Kiwi Bloke on 05/04/2020 10:30:57
              #462448
              Bazyle
                @bazyle
                The op has decided on his method but here are a few ideas for the next problem.
                Please make sure full information is given at the start.
                A perfectly adequate fixed steady can be made out of wood and some brass screws.
                If an item that needs support from a steady is not round it can be set in a metal sleeve using hot melt glue or even epoxy filler if thickly coated with wax for later release of the filler.
                When a deep hole absolutely has to be drilled from one end it helps to rotate both job and drill ie holding in the chuck and using a toolpost spindle or a method of rotating a tailstock drill chuck.
                #462458
                Former Member
                  @formermember19781
                  #462468
                  Les Jones 1
                    @lesjones1
                    Would it not be easier to have the bearings in the wheels and the axle fixed. If it was done that way the hole would not need to be so precise. It could be clamped in position with grub screws. Also if it was to be a working model the wheels should not be locked together.
                    Les.
                    #462503
                    Old School
                      @oldschool
                      Les Jones, It will be a working model and yes the driven wheels are on a fixed axle, it’s a tether car and runs in a circle about 60 feet diameter. The lack of a differential does not appear to cause a problem it been done this way for around 70 years and speeds are now in excess of 200mph.
                      Oliver
                      #462506
                      Circlip
                        @circlip
                        On another forum, trying to identify an electric motor type and the possible connection combination from a photo in the first posting, partially showing the spec plate was eventually solved after five pages and sixty three "Mine's bigger than yours" suppositions by the inclusion of a second photo clearly showing not only the original volts/current spec but also THE MANUFACTURERS LOGO and motor TYPE REFERANCE, despite further photo shot request back on page one.
                        Back on page one, first entry, we have a photo of the axle casting. After various suggestions of how to achieve a solution, one suggestion is discounted by the O/P telling, "you can't do that because there's something on the other side of the casting you can't see, and I obviously can't be bothered to show at the first posting with an opposite side photo."
                        FCS will those giving a countdown conundrum at least give ALL the letters to brain sucking problems before shooting us down with "Ahh but you can't do that BECAUSE – – – – "
                        Regards Ian.
                        #462530
                        Les Jones 1
                          @lesjones1
                          As the circle is 60' diameter i agree that the wheels are on the same axle does not matter. I am confused as it is a fully functional replica car how you are going to drive the axle. Are you going to machine out the diff housing and use bevel gears so the drive system is similar to the original or is the drive via spur gears or belt to a point close to a wheel ? If it is the second method how can it be considered a replica ?
                          Les.
                          #462537
                            Would also help if people read what info has been given "a solid axle with a bevel gear"
                            Replica of  a period tether car not a replica of an actual car.
                            Edited By JasonB on 05/04/2020 17:30:26
                            #462540
                            Les Jones 1
                              @lesjones1
                              Sorry for missing those points.
                              Les.
