Help to identify Lathe
Home Forums General Questions Help to identify Lathe
  • #552127
    James Hendry 1
      @jameshendry1
      lathe 2.jpgHello
      Looking for some help , can anyone identify this lathe ' obviously very old as it has been 'Foot Powered' in the past . Any ideas of Manufacturer and year of manufacture , any idea if I can get any literature on it. Many Thanks Jim
      #28243
      James Hendry 1
        @jameshendry1
        #552135
        Brian Wood
          @brianwood45127
          Hello James,
          My guess is a Drummond. There are plenty of owners who will give you a better opinion and you will get a lot more information from the Drummond entry on Tony Griffith's superb archive website—-www.lathes.co.uk
          #552141
          Keith Long
            @keithlong89920
            Yep, Drummond M type.
            For a LOT of info try the "[email protected]".
            Once you've become a "member" you can access the files and you'll find a load of information about all of the Drummond manufactured lathes. As a "non-member" you should still be able to see the topics under discussion and get a feel for the depth of knowledge, friendliness and helpfulness of the rest of the group.
            Keith
            #552155
            Ady1
              @ady1
              Drummond M. Solid as a rock. Loads of people still use them and lots of info about on the net
              #552174
              James Hendry 1
                @jameshendry1
                Thanks for info guys , yes Drummond M Type , I have now downloaded plenty reading material
                Thanks again
                Jim
                #552179
                Howard Lewis
                  @howardlewis46836
                  Have never owned one, but know that there are folk who do good work on them
                  (An ex work colleague boughtb one for £10 as "surplus to requirements" from our R & D area. I just wish that i could produce the sort of work that he does with it, dwpite being at least a hundred years old. (Drummond Lathe not colleague )
                  You have the potential for Years of pleasure and useful work.
                  Enjoy!
                  #552206
                  Pete Rimmer
                    @peterimmer30576
                    Drummond M as said but whomever had it in that corner didn't use it there. You need good access to the end gears which are fiddly enough to swap about but stuck against the wall like that would be very frustrating.
                    #552242
                    Nicholas Farr
                      @nicholasfarr14254
                      Hi, I would swap that on / off switch with a NVR start / stop before I use it, if it were mine.
                      Regards Nick.
                      #552310
                      Dave Halford
                        @davehalford22513
                        You can get a simple non latch RCD that fulfills the NVR duty for small motors and still keep the handy on/off switch
                        #552324
                        Nicholas Farr
                          @nicholasfarr14254
                          Hi, Dave, one of those non latch RCD's would suffice in the event of a power cut but apart from the switch and the wiring looking untidy and a potential safety hazard, a proper start / stop e.g. similar to NVR Switch will include an easy to reach and knock off, emergency stop button.
                          Regards Nick.
                          #552491
                          David George 1
                            @davidgeorge1
                            Hi James. have a look on here. https://groups.io/g/drummondlathe there is loads of help and information on there. Join and look in the files section.
                            David
                            #552510
                            Lee Rogers
                              @leerogers95060
                              Very early Drummond M Type . Belt drive is the give away.
                              #552657
                              Rob McSweeney
                                @robmcsweeney81205
                                If you do Facebook , there is also a Drummond?Myford group on there, which is more active than groups.io, and much easier to post photos to
