helical gear supplies
Home › Forums › General Questions › helical gear supplies
  • #182637
    clogs
      @clogs
      Hi all, looking for a supplier of Helical gears….prefer from stock….
      I need a matched pair between 75-100mm about 20-25mm tooth thickness and
      hardened …
      these are to run in mesh one above the other to reverse the direction of the driven gear…..to transmit 2-5hp at varying speeds…..constant load…..
      this is to drive a camshaft (4 cylinder petrol) in the past they were driven by ally or even fiber gears meshed with a steel one…
      any ideas…many thanks Clogs
      #23764
      clogs
        @clogs
        #182638
        Les Jones 1
          @lesjones1
          One possible solution is two sets of replacment angle grinder gears that are sold on eBay. I do not know if any of them would be as large as 75mm (I assume this is the diameter.)
          Les.
          #182640
          davidsuffolk
            @davidsuffolk
            I found Paul Wheeler at Cross & Morse of Birmingham very helpful. 021 360 0155. They have a online catalogue so you might find what you seek there. I ordered a pair of bevel gears and they were delivered the following day.
            #182644
            John Stevenson 1
              @johnstevenson1
              HPC Gears at Chesterfield.
              **LINK** Also do a priced on-line catalogue.
              Only problem with stock ears is they are usually pilot bore as they don't know what you want them for and therefore unhardened although you do have a choice of materials.
              #182646
              Bob Brown 1
                @bobbrown1
                ondrives list helical gears **LINK** case hardened so bore can be machined to suit.
                Bob
