Hard felt alternatives for wipers?
Home › Forums › Workshop Tools and Tooling › Hard felt alternatives for wipers?
Viewing 14 posts - 26 through 39 (of 39 total)
  • #120725
    IanT
      @iant
      Hallo Dias, yes – I believe you are correct in that it should be a "wool" felt – and although industrial felts are often mixed with other materials, I believe even these are still 90-95% wool based. As an aside, my old Myford Super7 simply has felt wipers on the way but swarf does get embeded in it. The Atlas has this two layer approach – felt "oilers" and plastic wipers in front of them – so Atlas obviously thought this was advantageous. I'm now thinking of adding a leather "wiper" in front of the Myford felt retainer and see if this has a useful effect. Regards, IanT
      #120732
      Chris Trice
        @christrice43267
        Surely any wicking action of felt happens between the fibres rather than inside them. How much oil can you hold inside a wool fibre? I think there’s a bit of over analysis going on. Regular applications of the oil gun probably do more good.
        #120735
        Andyf
          @andyf
          You might buy a hard felt buffing wheel, and cut it up.
          My Chinese lathe has synthetic rubber wipers, like windscreen wipers, and they seem to have worked OK for the last 6 years.. You could try cutting up lengths of wiper blade, if you can devise a way to mount them.
          Andy
          #120760
          Russell Eberhardt
            @russelleberhardt48058
            Posted by IanT on 27/05/2013 09:21:14:
            My Atlas lathe had rubber and felt wipers when purchased in the 1970s. The rubber wipers had degraded somewhat with the oil so I replaced them with a synthetic rubber (butyl rubber I think) and they are still in use. Perhaps it's time I made a new set!
            Russell.
            #120769
            John McNamara
              @johnmcnamara74883
              Hi Ian T
              I had to replace some perished rubber wipers on my lathe. I had some medium soft leather sheet to hand about 2mm thick and temporally cut some leather wipers (face side up the soft back touching the V ways. On my lathe the wiper is retained on the saddle by a metal clamp and a couple of screws.
              I cut the leather so that it formed an L, so it goes down under the clamp then turns about 5mm along the bed forming a good dirt seal over each V way.
              That was about 5 years ago… So I guess it is not temporary fix any more. it is still not worn much
              The leather absorbs oil without a problem. I am not sure how it would work with alkaline soluble oil, leather being organic? I dont use it so no problem.
              Cheers
              david newman 9
                @davidnewman9
                I have some of the real stuff came from a print works 30 years ago over the years have made wipers from it and it is perfect . If it's only a small ammount you require let me know and i'll send you a piece.
                David
                #120776
                Bazyle
                  @bazyle
                  DIY it. Any old moth eaten bit of genuine wool jumper or sock stuck in the washing machine with every wash for a month will shrink down ot a nice bit of felt. Useful for polishing cloth too.
                  Felt making is a craft hobby these days. That is the actual making of felt from the fibres so I guess one could get custom made wipers!
                  If I'd thought of it when that blasted sheep got into my garden last month I could have given it a good combing in exchange for the wallflowers it ate.
                  #120821
                  Gordon W
                    @gordonw
                    Another source is door draught proofers, look at some in DIY shops etc., some are near ideal. My Grandma made felt, so it can't be too difficult.
                    #120824
                    Russell Eberhardt
                      Posted by Bazyle on 27/05/2013 17:13:51:
                      I thought you had to put it in a bucket of urine and stamp on it for a few hours – not tried it myselflaugh
                      Russell.
                      #120828
                      IanT
                        @iant
                        I think I'll pass on the bucket Russel – my Manager already complains about the pong from cutting oils etc – although I find it quite aromatic. Anyway – I've ordered 6mm and 4mm sheets of 150mm square oil felt from Vintage Cars as suggested. There was a minimum postage charge of £4.50 – so I splashed out on an extra sheet! Last of the big spenders – but we have to keep the economy turning over! smiley Thanks again for all the help. Regards, Ian T
                        #120847
                        Ian S C
                          @iansc
                          Not sure how it goes, but there is something about felt hats, hatters, and mercury = Mad Hatter.Ian S C
                          #120853
                          Bazyle
                            @bazyle
                            Mercury was only used to add a glisten to the knap of top hats as a finishing process, not as part of felt making.
                            #120865
                            Russell Eberhardt
                              Posted by Bazyle on 28/05/2013 16:31:00:
                              .. and in "carroting" a process that removed fur from pelts before making it into felt.
                              Russell.
                              #487058
                              Mike Donnerstag
                                @mikedonnerstag
                                I realise this thread is old, but for those interested, I found this on eBay. It's 100% wool and used for oil seals:
                                nAAAOSwGeFbhk9d">https://www.ebay.co.uk/itm/Wool-felt-fabric-100-natural-2-30mm-thick-white-beige-ivory-pressed-plain-sheet/202418889991?hash=item2f211b2507:gnAAAOSwGeFbhk9d
                                Edited By Mike Donnerstag on 22/07/2020 10:02:45
