Guess the Chemical?
Guess the Chemical?
Home › Forums › The Tea Room › Guess the Chemical?
Viewing 25 posts - 26 through 50 (of 55 total)
  • #421231
      It's water…
      I think the clue was " If breathed in, move person into fresh air. If not breathing, give artificial respiration. "
      Clearly after that initial insight the person filling it in just went with the default low-hazard answers.
      David Colwill
        @davidcolwill19261
        SECTION 5: Firefighting measures
        5.1 Extinguishing media
        Suitable extinguishing media
        Use water spray, alcohol-resistant foam, dry chemical or carbon dioxide.
        5.2 Special hazards arising from the substance or mixture
        No data available
        5.3 Advice for firefighters
        Wear self-contained breathing apparatus for firefighting if necessary.
        I had thought water but had ruled it out due to the above!
        Regards.
        David.
        #421238
        Frank Gorse
          @frankgorse
          I believe it’s also called di-hydrogen monoxide which sounds very nasty.
          #421245
          V8Eng
            @v8eng
            I am very puzzled about extinguishing burning water (can it catch fire) using water perhaps somebody can explain that one?
            #421246
              Posted by Neil Wyatt on 28/07/2019 10:04:23:
              It's water…
              Very naughty of them. This excerpt from an MSDS for Water may be more typical:
              Even though it fails to mention that asbestos burns in the nasty stuff, this MSDS is more exciting.
              nerd
              Robin Graham
                @robingraham42208
                Posted by Michael Gilligan on 28/07/2019 07:29:33:
                Posted by Robin Graham on 28/07/2019 01:05:53:
                +1 for water – it's got to be nuts of Neil wouldn't have posted. Had a look at the MSDS for Cleanline deionised water:
                Ingestion: Rinse mouth thoroughly with water. Give plenty of water to drink. Get medical attention if any discomfort continues.
                Robin.
                Whilst the statement appears ridiculous, Robin … I believe that there is a safety risk associated with deionised water, due to the use of Sodium Hydroxide in its production.
                Well, OK, maybe! I picked that at random because of its apparent absurdity which seemed to match Neil's example.
                I'd be quite unhappy if I found harmful levels of NaOH in the deionised water I use though – it wouldn't really be deionised! The MSDS I quoted from gives a maximum pH of 9.0 which isn't too corrosive – the upper limit for potable water is 8.5 I think.
                Apologies if I've got it wrong – I'll wash my mouth, or at least my typing fingers with soap (pH around 10) if so wink
                Robin
                #421362
                  Posted by Robin Graham on 29/07/2019 00:03:18:
                  Well, OK, maybe! [ … ]
                  Pedant that I am, Robin … I did carefully use the term 'safety risk' rather than 'safety hazard'
                  … my logic being that although the product should be within spec. there is a specific risk associated with the process by which it is [presumably] manufactured. This appears to be recognised by the inclusion of reference to Sodium Hydroxide in that MSDS.
                  For what it's worth [admittedly not much in the present context], there is an outline of the production process here: **LINK**
                  http://www.tmasc.com/di%20water%20specs.htm
                  Robert Atkinson 2
                    @robertatkinson2
                    A bigger risk with distilled or DI water is mixing containers. Many years ago I worked for a small airline on an island and we did frequent compressor washes of the turboprop engines but were still having sulphidation issues on the blades. The washes used distilled water bought in large containers from a local supplier. Turned out that their main market was the motor trade and they were not fussy about cross contamination between battery acid and water.
                    I found out when asked to pick up an order from Boots as I was going into town. My little car was totally filled with 2l bottles of distilled water. When I found out what was going on I suggested an Elgastat deioniser. It took a bit of convincing (DI could strip ions from the blades but as we added a detergent to the wash this was moot) but they changed to DI and had no further issues. It also cured the high failure rate we were getting with the "wet" NICAD aircraft batteries.
                    Robert G8RPI.
                    #421380
                      Curious 'fact' I picked up somewhere is that drinking nothing but de-ionised water for too long is unhealthy. Something to do with kidneys requiring trace ions to function properly. I also believe drinking water made by bulk de-ionising sea-water has salts added back before being piped to customers.
                      Can de-ionised water damage kidneys? Now I've read my own post again I have doubts…
                      not done it yet
                        @notdoneityet
                        Posted by SillyOldDuffer on 29/07/2019 09:20:32:
                        One’s blood electrolytes would come under severe strain in that scenario. Only true if the person was not eating anything else at all, I would suggest, as there are loads of ions in most foods (too much salt in many!)?
                        #421406
                        Nicholas Farr
                          @nicholasfarr14254
                          Hi NDIY, might be worth looking at this **LINK** scroll down to Health effects of drinking purified water, also this **LINK** I think the main concerns are that the deionised water may strip your body of important minerals over time.
                          Regards Nick.
                          #421419
                          Martin Kyte
                            @martinkyte99762
                            Toxic in large quantities if ingested (Brain swelling, fits, coma, death)
                            regards Martin
                            #421421
                            not done it yet
                              @notdoneityet
                              Posted by Nicholas Farr on 29/07/2019 11:14:40:
                              Regards Nick.
                              Hi Nick,
                              This bit from the first link really sums it up, I think.
                              Quote ”This results in demineralized water, which has not been proven to be healthier than drinking water. The World Health Organization investigated the health effects of demineralized water in 1980, and its experiments in humans found that demineralized water increased diuresis and the elimination of electrolytes, with decreased serum potassium concentration. Magnesium, calcium and other nutrients in water can help to protect against nutritional deficiency.” Unquote
                              Not proven (either way?) and as I indicated, there are plenty of minerals in a proper, balanced diet. I’m most certainly not “nutritionally deficient”. Are you?smiley Somehow I doubt that would be the case for the vast majority on here.
                              Some Scots must be quaking in their shoes – well at least those that live at altitude and drink run-off from granite rocks – long before it has chance to collect lots of minerals.
                              De-ionised water might be classed as a ‘junk’ drink. Perhaps like a lot of the ultra-processed junk some people eat?
                              I would suspect that the ‘five-a-day’ would likely counteract any mineral loss without needing extra protection via the water one drinks.
                              But it seems clear that you must be agreeing with me – that it is blood electrolytes that are the problem, not the kidneys directly?
                              Regards, NDIY
                              Edited By not done it yet on 29/07/2019 11:56:13
                              #421425
                              JA
                                @ja
                                Is drowning a health risk?
                                #421429
                                Robert Atkinson 2
                                  @robertatkinson2
                                  A weird one is "Smartwater" from Coke where they distil perfectly good British spring water and then add Calcium Chloride, Magnesium Chloride and Potassium Bicarbonate back in! For starts if you are going to distil it why use spring water rather than tap water?
                                  Bizarrely (to me anyway) people buy the stuff. I guess they are the same people who pay 3 to 4 times as much for the same painkiller or other medication with a fancy name and packet as the generic version. I just checked Boots website Neurofen 200mg tablets 14p each, generic 3p each. Neurofen is more than 4.5 times the price).
                                  #421432
                                  duncan webster 1
                                    @duncanwebster1
                                    Many moons ago the New York health authority tested various brands of bottled water for purity. The best was the stuff that comes out of the tap at very little cost. Just shows the power of advertising
                                    #421438
                                      Posted by duncan webster on 29/07/2019 12:52:55:
                                      Sorry, Duncan … I can't afford to import vintage tap-water from New York
                                        Posted by Michael Gilligan on 29/07/2019 13:08:39:
                                        A similar UK test many tears ago scored Welsh tap water highest.
                                          Posted by Robert Atkinson 2 on 29/07/2019 12:40:16:
                                          Ordinary tap water is legally spring water if it comes from a groundwater source and meets drinkability standards.
                                          I think it is possible to fill 'spring water' bottles directly from the water main in some parts of the country.
                                          Mineral water has to have special certification.
                                          mark costello 1
                                            @markcostello1
                                            I live near a natural spring, My MIL also uses it for Her water. Down the road it is used for brewing beer and bottled water. The beer is sold locally and gets big raves. The water is shipped out and probably sold where no one knows about where it comes from. Other bottled water does indeed come from other places city water. They are shipping city water to Us from 90 miles away. We have no problems supplying Our own city water.
                                            #421515
                                            Jon Lawes
                                              @jonlawes51698
                                              When posted on to Harriers a rite of passage was to drink a glass of the de-ionised water used for injection into the engine when hovering. It might have just been water but you'd spend the day in the toilet.
                                              #421520
                                              JA
                                                @ja
                                                The water out of my taps comes from Birmingham! Sometimes the smell of chlorine is almost overpowering.
                                                #421553
                                                Howard Lewis
                                                  @howardlewis46836
                                                  JA
                                                  Not may people seem to survive serious drowning, so it must a SERIOUS risk to life.
                                                  water is safe if drunk in accordance with the safety instructions, and in the right spirit, I am told.
                                                  #421556
                                                  CHARLES lipscombe
                                                    @charleslipscombe16059
                                                    Many people in Australia outside of the cities use collected rainwater as their only source of water for drinking washing etc. Where I live, we do have mains supply but I collect rainwater for use on the veggie patch and in my home brewing. Not sure whether it affects the taste of the beer as I have never tried brewing from the horribly chlorinated and fluoridated stuff that comes through the mains.
                                                    Chas
                                                    #421561
                                                    JA
                                                      @ja
                                                      Posted by Howard Lewis on 29/07/2019 22:37:46:
                                                      Whisky?
                                                      I drink it neat.
                                                      Edited By JA on 29/07/2019 23:36:49
