Guess the Chemical?
Guess the Chemical?
Home › Forums › The Tea Room › Guess the Chemical?
Viewing 25 posts - 1 through 25 (of 55 total)
  • #421131
      For a bit of fun, here are some excerpts from a Manufacturer's Data Sheet. Can anyone guess the chemical?
      SECTION 4: First aid measures
      4.1 Description of first aid measures
      If inhaled
      If breathed in, move person into fresh air. If not breathing, give artificial respiration.
      In case of skin contact
      Wash off with soap and plenty of water.
      In case of eye contact
      Flush eyes with water as a precaution.
      If swallowed
      Never give anything by mouth to an unconscious person. Rinse mouth with water.
      4.2 Most important symptoms and effects, both acute and delayed
      The most important known symptoms and effects are described in the labelling (see section 2.2) and/or in
      section 11
      4.3 Indication of any immediate medical attention and special treatment needed
      No data available
      SECTION 5: Firefighting measures
      5.1 Extinguishing media
      Suitable extinguishing media
      Use water spray, alcohol-resistant foam, dry chemical or carbon dioxide.
      5.2 Special hazards arising from the substance or mixture
      No data available
      5.3 Advice for firefighters
      Wear self-contained breathing apparatus for firefighting if necessary.
      SECTION 7: Handling and storage
      7.2 Conditions for safe storage, including any incompatibilities
      Store in cool place. Keep container tightly closed in a dry and well-ventilated place.
      8.2 Exposure controls
      Eye/face protection
      Use equipment for eye protection tested and approved under appropriate government standards such as NIOSH (US) or EN 166(EU).
      Skin protection
      Handle with gloves. Gloves must be inspected prior to use. Use proper glove removal technique (without touching glove's outer surface) to avoid skin contact with this product. Dispose of contaminated gloves after use in accordance with applicable laws and good laboratory practices.
      Wash and dry hands.
      Body Protection
      Impervious clothing, The type of protective equipment must be selected according to the concentration and amount of the dangerous substance at the specific workplace.
      #35562
          Does it begin with M?
          #421133
          John Rutzen
            @johnrutzen76569
            Common Salt?
            #421134
              Glycerol?
              #421136
              lfoggy
                @lfoggy
                Those are all generic warnings so could be almost anything. I was going to guess sodium chloride as well but I will say sodium bicarbonate.
                #421137
                Robert Atkinson 2
                  @robertatkinson2
                  Could be anything. I've noticed that a lot of Safety Data Sheets tend to err to the "safe" side with all sorts of over the top precautions. Not really helpful. Amongst other thingss if you put lots of nonsense on a well esablished materail it "dilutes" th importance of the precautions and can cause them to be ignored on worse materials.
                  Once had a customer send a sample of liquid they wanted us to test on a disenser we made/ They sent the MSDS and the health and safety officer said it was too dangerous. The MSDS required gloves, face mask and respirator. It was labeled light mineral oil (liquid parraffin in UK). Strangely enough the safety officer was happy for us to use baby oil!!!
                  Robert G8RPI.
                  #421138
                  Brian Baker 2
                    @brianbaker2
                    Some alcholic beverage?
                    BB
                    #421139
                    not done it yet
                      @notdoneityet
                      Posted by JasonB on 27/07/2019 16:53:12:
                      Milk?
                      #421142
                      ChrisB
                        @chrisb35596
                        Acetone or MEK
                        #421144
                        Nicholas Farr
                          @nicholasfarr14254
                          Hi, it seems to reflect some white powder that was used by the company I used to work for many years ago. The powder was called Hydros, which I guess is a hydrogen compound. I never did know what it's exact definition was, but it was mixed with water and went into the process after being through an acid scrubbing process. Horrible smelling stuff and would take your breath away and would burn off rust, but any iron alloy that it came into contact with, would rust as soon as you let it dry. One danger side of it was, it was spontaneously combustible if it got damp, and that did happen once with a major fire ensuing as result with the fire brigade and chemical unit attending.
                          Regards Nick.
                          Edited By Nicholas Farr on 27/07/2019 17:52:59
                          #421145
                            Posted by lfoggy on 27/07/2019 17:09:35:
                            Not quite, for example the Firefighting measures include: 'Suitable extinguishing media. Use water spray, alcohol-resistant foam, dry chemical or carbon dioxide.' So it burns, and can be put out by water. That eliminates all non-combustibles like Common Salt, but also Fats and Oils. The warning about alcohol resistant foam indicates this is an alcohol or something like an alcohol, perhaps a ketone.
                            Whatever it is it's relatively harmless. It's not Chlorine Trifluoride!
                            Robert Atkinson 2
                              @robertatkinson2
                              Posted by SillyOldDuffer on 27/07/2019 18:09:50:
                              Sorry Dave see MSDS for salt from Fischer scientific similar firefighting (just plain foam though). I've never seen salt burn!
                              https://fscimage.fishersci.com/msds/21105.htm
                              Robert G8RPI.
                              Edited By Robert Atkinson 2 on 27/07/2019 18:43:53
                              #421147
                              Bizibilder
                                @bizibilder
                                Distilled (or deionised) water.
                                #421162
                                  Posted by Robert Atkinson 2 on 27/07/2019 18:32:26:
                                  Robert G8RPI.
                                  Glad I'm not a fire-fighter. Spraying water on molten Sodium Chloride generates Hydrogen Chloride and the reaction is violent. I believe a cupful of molten salt tipped into a bucket of water goes bang.
                                  Similarly spraying a lot of water onto red-hot coke normally puts the fire out. Obviously water is safe. Or is it? Not if the amount of water is kept low relative to the amount of coke. In suitable proportions and when hot enough, Carbon reacts with the water and converts it into a mixture of Hydrogen and Carbon Monoxide. Which can go bang, and is toxic!
                                  Don't think either disaster is likely to happen in my workshop! I reckon MSDS appear over-cautious in the face of common sense because they're covering what might happen in an industrial context. World of difference between salt on the dining table and several tons caught in a fierce fire, fire-brigade on the way.
                                  Buffer
                                    @buffer
                                    Marmite
                                    #421195
                                    Ian Johnson 1
                                      @ianjohnson1
                                      MSDS sheets are designed to scare people to death! And as others have said, this one could be anything, so I'll guess at weak Acetic Acid, it's what I pour over my chips. I prefer to call it by its proper name – Vinegar!
                                      Sillyolddufferr mentions Sodium, I was an apprentice on the Sodium plant, if you melt salt (Sodium Chloride) you split it into its metallic compound Sodium and Chlorine gas (that's the Chloride). It was an interesting if scary place to work, watching the process guys on top of the cells puddling the molten sodium by hand! then It was cast into large ingots or transferred into a special heated road barrel. The plant was decommissioned in the 90's.
                                      You put out a Sodium fire with salt, lots of salt!
                                      #421199
                                      Robin Graham
                                        @robingraham42208
                                        +1 for water – it's got to be nuts of Neil wouldn't have posted. Had a look at the MSDS for Cleanline deionised water:
                                        Ingestion: Rinse mouth thoroughly with water. Give plenty of water to drink. Get medical attention if any discomfort continues.
                                        Robin.
                                        #421201
                                        Ed Duffner
                                          @edduffner79357
                                          nitrocellulose lacquer?
                                          Ed.
                                          #421206
                                          Alan Charleston
                                            @alancharleston78882
                                            Ethanol?
                                            Alan
                                            #421208
                                            Raymond Anderson
                                              @raymondanderson34407
                                              No idea what it could be but… I know what it is not and that is… Chlorine Triflouride smile
                                              #421210
                                                Posted by Robin Graham on 28/07/2019 01:05:53:
                                                Robin.
                                                Whilst the statement appears ridiculous, Robin … I believe that there is a safety risk associated with deionised water, due to the use of Sodium Hydroxide in its production.
                                                Blue Heeler
                                                  @blueheeler
                                                  Not sure what Neil's is, but beware of Palmolive Shaving Foam !
                                                  Shaving Cream
                                                  #421224
                                                  Kiwi Bloke
                                                    @kiwibloke62605
                                                    If it's whisky – or indeed any other alcoholic beverage – I shall continue to use it in the manner to which I am accustomed, DIRE WARNINGS notwithstanding.
                                                    #421227
                                                    Geoff Theasby
                                                      @geofftheasby
                                                      Dave, small amounts of water added to red hot coke = Producer Gas? Some railway locos were designed to generate and use it.
