Gluing Plexiglass to brass
Home Forums General Questions Gluing Plexiglass to brass
  • #525577
    nigel jones 5
      @nigeljones5
      Ive just made some oilers for my Corliss model from brass and plexiglass. I bonded them together using loctite 272 but they came apart. Next I will try araldite but will it withstand being in constant contact with oil? thanks
      #27952
      nigel jones 5
        @nigeljones5
        #525590
        Ramon Wilson
          @ramonwilson3
          In a word fizzy – yesthumbs up
          I used the plastic tube protectors from small cutters for some and others were made using the clear protectors off artists paint brushes which can be 'gin clear'. I use the non fogging super glue or epoxy – either has stood the test of time
          Tug
          #525591
          not done it yet
            @notdoneityet
            No idea what you are actually making. No doubt methyl methacrylate monomer is available somewhere? With hardener it will dissolve the surface so act like a solvent glue as used by plumbers. Probably rough brass (or even thread it?). We used it for ‘welding together’ radioactive sources, back 50 years ago. They were not expected to leak.🙂
            Edited By not done it yet on 07/02/2021 22:25:36
            #525637
            Bo’sun
              @bosun58570
              As Ramon says. If using Super Glue, use a "non-fogging" one. To be honest, I didn't know such a variant existed. Just goes to show.
              #525639
              Ady1
                @ady1
                pinkgrip
                #525640
                John Haine
                  @johnhaine32865
                  Gorilla Glue Clear
