F1 shaper
F1 shaper
Home › Forums › General Questions › F1 shaper
  • #186855
    Rik Shaw
      @rikshaw
      My shaper has at sometime in its life been fitted with a single phase 240v motor. The two speed pulley on the motor driving on the smallest and slowest setting is still way to fast for some jobs so I need to find an EASY way to slow it down.
      Without going through all the faf involved with buying/making another pulley is it possible to put something like this:
      http://www.ebay.co.uk/itm/New-High-torque-50V-220V-AC-Motor-Speed-Controller-Power-2000W-/321726558855
      between the three pin plug and the motor to get the desired result?
      The identification plate on the motor is unreadable but judging by the physical size I would guess it to be between 1 1/2 and 2 HP.
      You will have gathered that my electro-intelligence is non existent – sorry – however, I can make a blinding fish curry.
      Rik
      Edited By Rik Shaw on 18/04/2015 17:20:37
      #23823
      Rik Shaw
        @rikshaw
        #186857
        Les Jones 1
          @lesjones1
          Hi Rik,
          Almost certainly no as it most likely an induction motor. The speed controller in your link will only work with a series wound motor. (Also known as a universal motor.)
          I just had another look at the advert and noticed this amusing claim "reverse polarity protection" on AC.
          Les.
          Edited By Les Jones 1 on 18/04/2015 17:38:28
          #186862
          paul 1950
            @paul1950
            the size of the motor will have nothing to do with the HP I have a very old 1/2 HP motor that is much bigger than a new 3 HP motor, my old shaper was well under 1 HP from what i can remember. the motor you have may be the wrong speed.
            #186882
            Robbo
              @robbo
              Rik,
              1.5 to 2 HP is way overpowered for an Alba 1A. Someone has probably just stuck on whatever motor he had, so it may well be over fast as well.
              The Elliott 10M used a 3/4 HP 3-phase motor with a speed of 1000 rpm, a strange figure and impossible to match in single phase. The Alba, being a precursor of the Elliott, may have been the same.
              I gave up trying to find a single phase motor and just stuck an inverter in an enclosure below the motor.
              Edited By Robbo on 18/04/2015 19:50:28
              #186888
              paul 1950
                @paul1950
                i gave up with my alba 1 and attacked it with a large hammer
                #186982
                Phil Whitley
                  @philwhitley94135
                  You can't go the speed control route with an old motor I am afraid Rik, it will almost certainly overheat, because slowing it down also slows down it's cooling fan. Check the rpm on the motor It should be 1440 or thereabouts, I bet it has been fitted with a 2880 from a compressor. single phase 1 1/2 to 2 hp motors will be cheaper than a VFD speed control, don't buy new, go to a motor repair and rewind shop.
                  Phil
                  #186989
                  Phil Whitley
                    @philwhitley94135
                    my Alba 1A is single phase, I am at the workshop tomorrow, I will check it out and see what speed and hp it is
                    Phil
                    #186992
                    John Stevenson 1
                      @johnstevenson1
                      They usually had a 6 pole motor on so 870 to 960 revs was normal motor speed.
                      #187017
                      daveb
                        @daveb17630
                        My Alba 1A was fitted with a 3/4HP single phase motor from new, sorry, can't remember the RPM, it was either 960 or 1400. I suppose you know there is a 2 speed gearbox as well as the double pulley? I never used the top speed, it was fast!
                        #187162
                        Phil Whitley
                          @philwhitley94135
                          Sorry Rik, didn't go today, there tomorrow though, and will let you know.
                          Phil
                          #187196
                          Rik Shaw
                            @rikshaw
                            I have just put a tacho on the motor spindle and it reads 1440. That's 440 to fast from what I have read on here. All remarks very helpful – thanks all and yes I do know I can select from 4 speeds. I dare not select the highest speed – I prefer the shaper to stay put in the workshop. smile
                            Rik
                            #187207
                            colin hawes
                              @colinhawes85982
                              My Elliott shaper has a 3/4 hp 960 rpm 3 phase motor, which has been altered to run on single phase. Colin
                              #188398
                              Phil Whitley
                                @philwhitley94135
                                Finally remembered, albeit too late John S is right (of course!) mine also has a 960 rpm motor, single phase, made by SEM in Beckenham, UK (Small Electroc Motors)#
                                Phil
                                #188400
                                Phil Whitley
                                  @philwhitley94135
                                  Mine is also 3/4 hp
                                  #188401
                                  Anonymous
                                    My shaper came without a motor. The manual quotes a hp rating but not a motor speed. I fitted it with a 4hp 4 pole three phase motor.
