ER 16 / 20 or JT2S, JT33 and JT6 Straight shank tooling
Home › Forums › Workshop Tools and Tooling › ER 16 / 20 or JT2S, JT33 and JT6 Straight shank tooling
  • #20222
    Oily Rag
      @oilyrag
      #537107
      Oily Rag
        @oilyrag
        I have been looking for 3/4" straight shank tooling adaptors to suit ER16 and ER20 collets or Jacobs taper mounts for JT2S and JT33 or JT6. There are plenty of ER collet chucks available but unfortunately they are all in 20mm shank diameters. The only ones available in 3/4" are from the USA. Anyone know of a supplier in the UK able to source these shank sizes from.
        The reason for the 3/4" shank is they are for a capstan turret and 3/4" is the small standard size for capstans. 1" and 1 1/4" being the larger sizes. I need 4 of these and may have to revert to making my own!
        Martin
        #537111
          Cylindrical grinding, between centres, might be an alternative
          … make an Imperial “Silk Purse” out of whatever 20mm “Sow’s Ear”
          Oily Rag
            @oilyrag
            I had considered that route Michael – but four shanks at £10 a throw to get ground (uness I do it myself with the toolpost grinder) is about half the cost of the 4 shanks! Why can't suppliers supply parts that are needed? Obviously there is a market in the US for these parts and they must be having them made in far off lands at the prices they are charging (about half the price of the parts here). What's the difference between supplying 20mm shanks and 3/4" shanks? Apart from 0.95mm!
            I guess there is no call these days for capstan tooling as the imported lathes do not appear to offer them as accessories.
            #537122
              Could you use a 16mm shank ER16 and make sleeves?
              #537124
              DC31k
                @dc31k
                #537125
                  Oily Rag
                    @oilyrag
                    Hi Jason,
                    I could and I probably have some suitable sleeves from my 'big' boring and facing head. The reason I need ER 16 or JT2S is I need to centre drill, drill through [7mm], then I need either a JT33 or JT6 to mount a suitable chuck or a couple of ER20 chucks to mount up and drill 27/64th, then clearance drill 1/2". This accounts for 4 stations on the 6 station turret capstan. The last 2 stations are taken up by an internal recess grooving tool and a chamfer tool.
                    I think the route I'm going to take is to make up the JT's I need onto some 3/4" bar.
                    #537134
                    Robert Butler
                      @robertbutler92161
                      Dear Martin
                      I think I have managed to send you a message!
                      Robert Butler
                      #537145
                      David Colwill
                        @davidcolwill19261
                        You may be able to get 4 morse taper and turn the taper off to give the 3/4 shank.
                        It is also worth going to eBay.com which will take you to the American site where such things may be floating around.
                        David.
                        #537146
                          Cutwel do 16mm shank ER16, oversized ER16 collets are available for 11mm which would take care of the 27/64ths from Gloster
                          #537148
                          David Colwill
                            @davidcolwill19261
                            You could also buy the 1/2" parallel shank arbors from Chronos for £4.50 each and sleeve them
                            Link
                            David.
                            #537151
                              You don't say how many you have to do that warrents the capstans use but you could simply sleeve the two drill bits
                              #537152
                              Oily Rag
                                @oilyrag
                                DC3,
                                Unusually, I missed the MSC site which is normally my first port of call. Thanks for reminding me, 2 x ER16's on order at the 'Sale' price; now, as there appears to be nothing other than ER16 in 3/4" shanks I'm going to make a couple of 3/4" x JT6 taper and JT33 taper shanks to fit my chucks to.
                                David, and others,
                                Yes, could do, but I worry the 1/2 shank will slip, I drive the capstan hard!
                                Jason,
                                140 off – definitely a Capstan job, then onto the other lathe, set up in back gear for tapping. They are special 'extended nuts' for an ambulance conversion for mountain rescue to Polaris 6 x 6 off roaders.
                                Thanks for the responses,
                                Martin
                                Edited By Oily Rag on 30/03/2021 19:21:09
