EN1A Leaded steel
EN1A Leaded steel
Home › Forums › General Questions › EN1A Leaded steel
  • #218840
    Dougie Swan
      @dougieswan43463
      Hi
      Can anyone tell me if en1a leaded steel would be ok for cylinder liners as opposed to cast iron. The piston would be aluminium with cast iron rings
      Thanks
      Dougie
      #24297
      Dougie Swan
        @dougieswan43463
        #218842
          I have used it on model aero engines with all iron pistons and it's quite happy at 8000rpm so should be fine on a slower reving engine like your marine one.
          Allow about 0.003" per inch dia on the piston so it can expand.
          J
          Edited By JasonB on 01/01/2016 13:00:36
          #218843
          Russ B
            @russb
            Yes that will be, I'm not sure if en1a is better or worse, I suspect the answer is application specific.
            #218849
            Emgee
              @emgee
              Hi Jason
              Were you using CI pistons lapped to suit bore and no rings ?
              Emgee
              #218850
                Yes lapped cylinder and then piston lapped into to the bore with 1000g SiC powder and oil.
