Double Clack
Double Clack
Home Forums Beginners questions Double Clack
  • #183326
    Dennis Rayner
      @dennisrayner52782
      I am just completing a Southworth steam water pump and I need it to share the clack bush on my boiler with the axle-driven water pump. I can't imagine them ever operating at the same time. Can anyone point me in the direction of drawings for a double clack valve? For what it's worth, the pipe size is 3/16".
      Many thanks
      #7523
      Dennis Rayner
        @dennisrayner52782
        #185722
        Dennis Rayner
          @dennisrayner52782
          "And some seed fell on stony ground" Ah well, I'm thinking of trying a different approach. I plan to tap into the existing axle pump feed via a T connector to the clack and put an inline check valve in each of the feeds before they T together.
          This will be under the footplate so it will keep the backhead looking more authentic – I wondered if anybody could see a problem with this approach?
          Should I remove the ball from the existing clack valve?
          Many thanks
          #185727
          david homer
            @davidhomer12226
            You should be able to a picture of one here
            http://modeleng.proboards.com/search/results?what_exact_phrase=double+clack&who_only_made_by=0&display_as=0
            You might also find some info if you look through John's web site
            David
            #185731
            MichaelR
              @michaelr
              There was a thread on this forum about a double clack with a drawing
              Edited By Stick on 06/04/2015 20:06:55
              #185732
                Posted by Stick on 06/04/2015 20:01:58:
                I wouldn't know one if it bit me on the leg … but
                I presume that this is the thread.
                MichaelR
                  @michaelr
                  Well done MichaelG, I searched the threads but couldn't find what I was looking for.
                  Stick.
                  #185755
                  doubletop
                    @doubletop
                    Posted by Dennis Rayner on 15/03/2015 15:52:38:
                    I had exactly the same problem and did try a 'T' in the line for the hand-pump on the assumption that the pump exerting the highest pressure would close the output valve of its opposite number and open the boiler clack. My laziness resulted miserable failure fixed by doing just as you are proposing no pictures or drawings though..Now you got me thinking what I did, I think I just copied a single clack and put two of them onto a T piece. I'll have to go and check.
                    Pete
