DOS (V6.3) Commands – Selecting file attributes for use with the DIR *.extn command
Home › Forums › CAD – Technical drawing & design › DOS (V6.3) Commands – Selecting file attributes for use with the DIR *.extn command
  • #594531
    Greensands
      @greensands
      Hi – Anyone out there with a knowledge of the old DOS commands? I have a number of DOS files on my workshop computer (W98) having a file extension .CON which I would like to be able to display in date order. Reference to the manuals indicate that the generic command DIR *.CON can be modified by a /switch attribute which I can get working when using /p (to display one screen at a time) but have not been able to get the /d attribute working in order to display the files in date order. Any suggestions as to where I am going wrong?.
      #21374
      Greensands
        @greensands
        #594534
        Grindstone Cowboy
          @grindstonecowboy
          dir *.con /od
          Edit – if you type any DOS command with the /? switch, it lists all available options e.g. dir /?
          Rob
          Edited By Grindstone Cowboy on 15/04/2022 14:23:27
          #594535
            Posted by Greensands on 15/04/2022 14:06:50:
            … I have a number of DOS files on my workshop computer (W98) having a file extension .CON which I would like to be able to display in date order. Reference to the manuals indicate that the generic command DIR *.CON can be modified by a /switch attribute which I can get working when using /p (to display one screen at a time) but have not been able to get the /d attribute working in order to display the files in date order. Any suggestions as to where I am going wrong?.
            Microsoft changed DIR slightly with every release! This website seems to cover all the variations.
            Try
            DIR *.CON /O:D
            or, to reverse the order
            DIR *.CON /O:-D
            /T controls which datetime is used by the sort if the default isn't what's wanted. TC=create; TA=last read; TW=last write
            GordonH
              @gordonh
              Greensands,
              Open up a DOS Shell by typing "cmd" (without the " symbols) in the search window then press enter.. The Dos pop up window will open. Typing "Help " followed by any command name, will display format of the command and the switches which can be used.
              One useful switch that is not listed is the > character followed by a file name. This will divert the screen output into the named file, a very useful feature
              Gordon
              Below is an example from Windows 10, I added the last line to show the piping command:-
              C:Usersgordo>help dir
              Displays a list of files and subdirectories in a directory.
              DIR [drive:][path][filename] [/A[[:]attributes]] [/B] [/C] [/D] [/L] [/N]
              [/O[[:]sortorder]] [/P] [/Q] [/R] [/S] [/T[[:]timefield]] [/W] [/X] [/4]
              Specifies drive, directory, and/or files to list.
              /A Displays files with specified attributes.
              attributes D Directories R Read-only files
              H Hidden files A Files ready for archiving
              S System files I Not content indexed files
              L Reparse Points O Offline files
              – Prefix meaning not
              /B Uses bare format (no heading information or summary).
              /C Display the thousand separator in file sizes. This is the
              default. Use /-C to disable display of separator.
              /D Same as wide but files are list sorted by column.
              /L Uses lowercase.
              /N New long list format where filenames are on the far right.
              /O List by files in sorted order.
              sortorder N By name (alphabetic) S By size (smallest first)
              E By extension (alphabetic) D By date/time (oldest first)
              G Group directories first – Prefix to reverse order
              /P Pauses after each screenful of information.
              /Q Display the owner of the file.
              /R Display alternate data streams of the file.
              /S Displays files in specified directory and all subdirectories.
              /T Controls which time field displayed or used for sorting
              timefield C Creation
              A Last Access
              W Last Written
              /W Uses wide list format.
              /X This displays the short names generated for non-8dot3 file
              names. The format is that of /N with the short name inserted
              before the long name. If no short name is present, blanks are
              displayed in its place.
              /4 Displays four-digit years
              Switches may be preset in the DIRCMD environment variable. Override
              preset switches by prefixing any switch with – (hyphen)–for example, /-W.
              C:Usersgordo>help dir >help.txt
              Edited By GordonH on 15/04/2022 14:39:18
              Edited By GordonH on 15/04/2022 14:41:03
              #594540
              Greensands
                @greensands
                Yes, I now have success!. Many thanks GC and SOD
                #594564
                Ady1
                  @ady1
                  I seem to have a residual bit of fluff in my head which says FAT32 was date orientated and NTSF was alphabetic
