Door stay help
Door stay help
Home › Forums › The Tea Room › Door stay help
  • #490311
    mechman48
      @mechman48
      Posted by Sam Longley 1 on 12/08/2020 06:50:54:
      Posted by AJW on 11/08/2020 21:33:01:
      how can they sell such a poor product?
      Well you bought one for a startwinkfrownsurprise
      Edited By Sam Longley 1 on 12/08/2020 06:51:43
      Well we've all done it with one item or another !devil
      George.
      #490317
      Robert Dodds
        @robertdodds43397
        AJW,
        Don't know the detail of your doors but I would be looking at the lengths of toothed rack as used to motor gates open and closed. A metre length for under £20 and a bit cut off could be used to slide in and out of mesh to either lock or release the doors.
        Bob D
        #490364
        AJW
          @ajw
          They are only standard back doors, one in the kitchen and one into my 'man cave'
          This is the type of friction stay fitted.
          https://www.ironmongerydirect.co.uk/product/concealed-door-limiting-stay-stop-upvctimber-947297
          Alan
          #490367
          MadMike
            @madmike
            I suggest that the "stay" is actually designed to stop the door opening past 90 degrees to thus prevent the door/farme/hinges becoming damaged. I am not aware of a "stay" designed for a full size door which is designed to hold the door at any fixed position between closed and the 90 degree position. A skiding block as described can only work in one position…….fully opened. Having sufficient friction to resist wind pressure, or allow easy opening/closing on a sliding stay is just about impossible. Again I suggest that the renedy should be provided by the suppliers. After all AJW when you asked for "stays" did you agree exactly what the fitting was supposed to achieve. the sliding device you have described is a stay designed to hold the door at 90 degrees.
            Incidentally the multiple position "restrictor stay" suggested earlier is designed for windows, and nor full size doors. It will give a retricted opening of probably not much more that 100-150 mm for ventilation without jeopardising security.
            Edited By MadMike on 12/08/2020 22:47:21
