That method needs a warning – a great way of breaking a tooth or two off the rack feed wheel. tt's probably ok with light cuts and narrow keys on soft materials.
I made something like this years ago and have even used it to gash silver steel. Not needed all that often but very useful when it is. The one I made went with a myford but the boxford came with one at the correct shaft height.
It was based on a casting but not this one just similar with simpler lighter linkages and a flat lever.
Too late to post a photo.
The hole for the slotting head is drilled and reamed with the casting or block of metal etc fixed to the cross slide so that is always on centre. Some one on here made one that fitted onto the toolpost recently to produce some straight knurled knobs.
Your right to wonder about setting the slotting tool height. If it's going on a commercially made spindle the key on that will be dead central. If you cut one on a pulley and go for a precise fit and it's off centre they wont fit together and out comes a file to correct it.
The best bet is to turn up a bush, slot that and check that it fits on the spindle then do the pulley when your sure it's ok. That's probably what he did.
Oh – it's also possible to slot a shaft but care has to be taken to make sure it doesn't get bent.
Edited By John W1 on 14/10/2015 23:38:54
Edited By John W1 on 14/10/2015 23:41:24
