Cool down a mini-mill motor.
Home Forums Workshop Tools and Tooling Cool down a mini-mill motor.
Viewing 25 posts - 1 through 25 (of 33 total)
  • #108481
    Johan Crous
      @johancrous15881
      I have a mini-mill with the classic motor (smooth, un-ribbed sides).
      When I mill a big cut it eventually get hot. I have to stop perodically to let the motor cool down. Same with my lathe.
      I have been thinking to add a fast running (computer type) fan on top to force suck air through the motor at high speed. This may assist the motor to take more time before I have to take a break.
      The ordinary 100mm (4 inch) fan is too big as the fans blades are extruding to past the holes in the top and the dead, solid area of the fan blocking the motor's holes. A 75/80mm (3 inch) will have a smaller inner area, causing the blades to be exactly over the breathing holes of the motor.
      I have read an article on Andyf's Warco WM180 lathe page about adding a computer fan to the motor to cool it down and this inspired me in this direction of thinking.
      Any ideas or references?
      #16976
      Johan Crous
        @johancrous15881
        #108482
        Sub Mandrel
          @submandrel
          Hi Johan,
          I have had similar thoughts in the past – the built in fan is ineffective at low speeds.. My thoughts are:
          • You need to make sure the air flows the same way as the built in fan sd they don't fight against each other.
          • If it needs to 'suck' rather than blow agood seal will be more important.
          • Make sure it can't suck swarf into the motor.
          martin perman 1
            @martinperman1
            Johan,
            Have you considered putting a tube on top of the motor to adapt to your 4" fan, have you also considered putting filter media across the air intake at the other end to stop muck going into the motor.
            Martin P
            Edited By martin perman on 12/01/2013 18:24:29
            #108491
            Johan Crous
              @johancrous15881
              Posted by martin perman on 12/01/2013 18:23:09:
              Johan,
              Martin P
              Martin,
              No I have not, but it is a very good idea. If the air goes from bottom to top I am going to do a filter, but it is not necessary if the air goes from top to bottom.
              I don't know if the motor has a fan at all. I will test tomorrow witha feather. I will then also see the air flow direction. The suggestion of a tube/funnel/shrowd is a very good idea, as I can then forece more air through the motor.
              Anyway, I doubt if the air will completely cool the motor down so that it does not go hotter than a certain amount to be able to run continious. If I can only slow the warming effect down by at least 50%, then I will be able to work longer. Maybe I must slow down the rate of feed to even more slow, as it is only a mini mill. I am now doing a big cut: a tool holder for a QCTP. Lots of milling through steel for a mini-mill, but it does just that.
              The next step will be for my lathe as well.
              #108499
              Sub Mandrel
                @submandrel
                Johan,
                The motors have a pressed steel fan inside. The efficiency of the fan is related to something like the square of the motor speed, so when running slow it hardly functions.
                I have done the task you are planning (milling QCTP blanks) and I found I could work for quite a long time without getting worried about a warm motor. How fast are you running the mill?
                Anonymous
                  The motor getting hot may not be a problem. Certainly induction motors are designed to run hot when operating at full load. Hot means you will burn yourself if you touch the motor casing.
                  #108508
                  FMES
                    @fmes
                    I have a portable magnetic drilling machine that suffers from slow speed lack of cooling, I made up a small adaptor to take a vacuum cleaner hose over the fan shroud, – start up the vac, no more cooling problems at slow speed.
                    Lofty
                    #108528
                    Sub Mandrel
                      @submandrel
                      Andrew.
                      These are permanent magnet DC brush motors. Hot casing means VERY HOT coils.
                      Anonymous
                        Neil,
                        Thanks for the information. In electric motors (DC and AC) it is common to have winding temperature ratings in the order of 100-200ºC. Granted in a DC brushed motor, with rotating coils, the cooling is less effective than an induction motor where the coils are static, but the case can still get pretty hot without a problem.
                        I suppose what I was really trying to say is there actually a problem, or is the OP just being understandable cautious?
                        #108536
                        Ian S C
                          @iansc
                          Even with a motor designed to run at higher temperatures, an extra fan to drop the temperature a little can't hurt. I believe that some high performance electric motors used in model boats are actually water cooled. Ian S C
                          #108539
                          Andyf
                            @andyf
                            I know from other forums that there have been occasions when small (up to around 600W) Chinese DC permanent magnet motors have overheated and burned out. The problem arises in high torque, low speed situations such as turning large diameters.
                            My lathe has such a motor, and even when running at high speed its internal fan doesn't shift much air. I fitted a computer fan to the end, blowing the same way as the internal one when running forward; Of course, when the motor is reversed the two fans fight one another, but the internal one is so weak that the external one wins, and in any case the motor is only reversed to reposition the carriage, rather than to do any real work. I'm not sure if Johan's mini-mill has a reverse switch for its motor, but if it does it will be used very rarely.
                            Andy
                            #108542
                            MICHAEL WILLIAMS
                              @michaelwilliams41215
                              Hello JC ,
                              (1) Fit an electronics style black anodised aluminium heat sink . One big enough to fit the motor would dissipate 70W easily while maintaining component temperature within limits .
                              They come ready made in all shapes and sizes or you could quite easily make one to suit .
                              When fitting ensure that the heat sink is in contact with the actual hot zone metal of the motor – no good fitting heat sink to an end cap or such like .
                              (2) Sharpen your cutters and use appropriate cutters .
                              Difference in input power between using newly sharp cutters and barely effective cutters can be several hundred percent .
                              Don't be too keen to use inserted tipped tooling on very small machines . Cut well when new but can absorb lots of power .
                              (3) I wouldn't recommend this but I've seen it done in industry :
                              Fit a water jacket and fill with soluble cutting oil !
                              Regards ,
                              Michael Williams .
                              #108562
                              Johan Crous
                                @johancrous15881
                                I have no idea at what power I am running the current job (I don't want to remove the job item I am working on before I am not done).
                                I am cautious (naturally). The motor is not getting as hot that I cannot touch it. It is still low enough that I can touch it without burning or without pulling away your hand when yoy touch it by accident. I guess still lower as bathing or shower water temperature.
                                I must also mention that the ambient temperature here in the summer is between 28 and 36 degrees of C (82 – 97 degrees of F). My swimming pool pump is equiped with cooling fins and it get very hot. Too hot to touch.
                                I just don't want to burn the motor of the mill. I have no previous experience with induction motors. At the low speeds I could not find the direction of air flow. I am now thinking of adding a plastin agricultural water pipe reducer over the motor that I can attach to the motor with a hose clamp. On the other side it is a little bigger, wher I would like to add a small extracter fan that can deliver 90 cfm air. I think this should delay the getting hot some time. I can even keep the fan running when the mill motor is swithed off. I guess it will assist a bit.
                                But again, I may be over cautious, but I have no experience of these type of motors.
                                Johan
                                #108563
                                  Johan,
                                  As a convenient point of reference [remembered from using laboratory glassware]
                                  If you can just hold the palm of your hand on the motor, without pulling away … it's probably around 70°C.
                                  Sub Mandrel
                                    @submandrel
                                    I have burnt out two mini lathe motors. You can keep them staggering on by shorting the blown coils – naughty but effective, but the slow speed perfomance suffers.
                                    I bought a spare from a genial chap out of the ME classifieds. When I cam to try it two coils were blown!
                                    Because it is an armature motor, the heat on the outside needs to get through the magnets and the casing – theres a lot of thermal inertia to overcome and the windings can blow with an impressive amount of smoke with the casing quite cool enough to touch comfortably. I think a fan has to be the best option.
                                    That's why my mini lathe is now powered by an ancient hoover fractional motor, as I have a tendency to abuse it work it quite hard. I tried an experiment an hour or two ago using my box tool to reduce 7mm stainless to 0.090" – a cut depth of over 90 thou which is going some for such a light lathe! I couldnt understand where teh swarf was going, until I realised it was widnin under the tool tip.
                                    Ian S C
                                      @iansc
                                      Neil,?? widnin under the tool tip. Ian S C
                                      #108651
                                      KWIL
                                        @kwil
                                        widnin=windingdevil
                                        #108652
                                        David Jupp
                                          @davidjupp51506
                                          Posted by Michael Gilligan on 13/01/2013 15:04:45:
                                          Johan,
                                          I'd suggest that the surface temperature probably isn't as high as that if you can hold your hand in place. Maybe with glassware you 'get away with it' because glass is not a fantastic conductor of heat, with metal object I certainly would not want to put my hand on anything very much above 50 C.
                                          #108667
                                          ChrisH
                                            @chrish
                                            I have a welding machine which used to overheat and cut out when doing any serious prolonged welding. I also fitted a computer fan – the first one that came available, no research or calcs done there – and it transformed the welder, you can weld all day with no problems now.
                                            #108673
                                            Gordon W
                                              @gordonw
                                              My lathe motor is a modern "tin" cased job, I had thought about drilling some extra holes for cooling. The welder was greatly improved by drilling extra holes, in the bottom and along the top edge, with feet to allow air flow. This mod. moved the machine up a class.
                                              #108674
                                              Clive Hartland
                                                @clivehartland94829
                                                Have you considered wrapping some small bore copper tubing around the casing and pump some water around to cool it? Needs a tight wrap though to make good contact.
                                                Quite feasable using a small pump and a header tank away from the machine. Ypu could even stick a thermometer in the tank to see the temp. rise.
                                                #108682
                                                Johan Crous
                                                  @johancrous15881
                                                  I have listened to several replies, also to one that said that the motor can still burn out if it gets too hot inside while you may get the external cool. I have decided on a fan and shrowd, but I am too lazy to make a big project yet, as I would like to evaluate first before I do the mod permanently, and only if it works.
                                                  I bought a 115 mm extracter fan tha can deliver 76 cubic meters of air per hour and that can run for a very long time. I have set it up to run permanently, as long as the mill is plugged in and the plug switched on, although the machine may be off.
                                                  The mill before anything done.
                                                  At the bottom of the motor there are four narrow grooves to circulate the air.
                                                  On top is a cover that needs to be removed. The little round holes on top is just for show and only air the bearing.
                                                  Below the cover there are 8 vetilation holes, but no fan. I guess the rotation of the armature will circulate some air, but very littllow speed, or almost nothing.
                                                  Don't laugh. A plumbing coupling fitting for toilet pipes, with a hole cut to allow for the motor's wiring. This fitting is made of white rubber and is flexible. Added to it is a hose clamp. One side ring on the narrow part (nearest to my hand) is cut away to make space for the hose clamp. The ridge is still visable.
                                                  Added to the motor with the hose clamp. The motor's wire can be seen extruding through the cut gap.
                                                  Air blowing in from the top will be forced through the motor's vetilation holes. None can get past the motor. The fitting will be a tight fir und the extracter fan. No air can escape and the fit is tight enough to keep the fan in place.
                                                  The fan in place. The fact that it is white is not so bad in appearance.
                                                  The fan's specs.
                                                  The current job. Quite a lot of steel to be removed. This will be a parting tool holder for a QCTP. I am cutting the dovetail here. Firt the innitial removal of lots of steel.
                                                  AND:
                                                  It works! It works! It works!
                                                  It did not get hot tonight. Just comfortable warm to the tough. I guess about 40 degrees of C. The fan is kept running in between stops so that the cooling effect may last. The sound is a very soft hum, like a running PC. The air is blown from the top downwards and can observed if you keep your hand close to the motor. Currently I am not interested in colouring it black. White is fine. Now I am not worried anymore.
                                                  Thanks for all the advice and encouragement.
                                                  Johan
                                                  #108691
                                                  Sub Mandrel
                                                    @submandrel
                                                    Well done Johan,
                                                    I think I shall follow your example, as with the belt drive conversion I'm working my X2 much harder.
                                                    For the record, the built in fan is at the opposite end to thebrushes, in the equivalent space at the other end, but it is crude and does little at anything less than high speeds.
                                                      Nice work Johan
