Colchester Bantam 2000
Home Forums General Questions Colchester Bantam 2000
  • #342138
    needleworks
      @needleworks
      The play in my cross slide is starting to really annoy me now so I reckon it's about time to replace the nut, or the screw, or both if that's what it needs. I assume it's going to be an acme thread, but on measuring, I can't decide if it's imperial or metric !
      I have measured it at 14.2 mm x 2.5 in metric, on the imperial side it measures .559 x 10 tpi.
      Has anyone previously done this fix that could give me some advice?
      Thanks in advance guys
      #25818
      needleworks
        @needleworks
        #342145
        Mick B1
          @mickb1
          .559" is 3 1/2 thou down from 9/16. My guess is imperial.
          #342146
          Mike Poole
            @mikepoole82104
            Does the scale on the handwheel not give away the pitch?
            #342156
            needleworks
              @needleworks
              Posted by Mike Poole on 18/02/2018 19:13:10:
              On the Bantam you have the luxury of both, pull the dial out it reads metric, push it in it reads imperial.
              #342158
              needleworks
                @needleworks
                Posted by Mick B1 on 18/02/2018 19:08:48:
                I thought of 9/16, but I can't find a left hand acme tap 9/16 x 10 tpi anywhere on the net
                #342164
                Chris Evans 6
                  @chrisevans6
                  Look for leadscrew makers on the net. Plenty about I bought a 1 metre length of 16mm left hand screw and matching nut very cheaply from Automotion Components. A bit of simple machining to cut the threaded part of the original screw off and spigot it onto the remaining part secured with a roll pin and a dab of Loctite. If the pitch is correct don't get to hung up about the diameter if replacing the nut. I got enough to make three cross slide screws and a nut for around £50/60.
                  #342174
                  Pete Rimmer
                    @peterimmer30576
                    Posted by needleworks on 18/02/2018 20:07:34:
                    You won't and it probably wouldn't help you anyway. IIRC the Bantam cross slide screw is a 2-start thread. .100" pitch but 5tpi lead.
                    #342175
                    Mike Poole
                      @mikepoole82104
                      Posted by needleworks on 18/02/2018 20:03:40:
                      Ah that makes life a bit more complicated.
                      #501865
                      Deleted Account
                        @deletedaccount69088
                        Posted by Chris Evans 6 on 18/02/2018 20:35:57:
                        I was wondering was there any centres on the leadscrew or whatever they are called to accurately place the bar between two centres?
                        #501872
                        Emgee
                          @emgee
                          You can easily confirm the pitch of the leadscrew by fitting a Dial gauge between the tool post and a chuck mounted rod, do 1 complete revolution of the handwheel and read the gauge, you will have to take up any backlash before doing the test revolution.
                          Emgee
                          #501885
                          Chris Evans 6
                            @chrisevans6
                            As I recall there are no centres in the replacement lengths of leadscrew. The threads are formed by rolling and I have found them to be very accurate. I simply cut off the required amount and held it in a 5C collet to turn the ends to suit. I made two cross screws and nuts from what I bought and still had enough over to make a third screw. After 5 or 6 years of regular use there is still no play in the first one I fitted so the spares are still on the shelf. I did add an additional oil point to lubricate the screw a bit better than original design.
                            #502008
                            Deleted Account
                              Posted by Chris Evans 6 on 17/10/2020 12:56:30:
                              thanks for the information. The collet idea would seem to solve the problem of centering things.
