Chester Conquest Mill
Home › Forums › Workshop Tools and Tooling › Chester Conquest Mill
  • #523333
    Chris Taylor 3
      @christaylor3
      I have a 5 year old Chester Conquest Super mill which I have recently fitted with 3 axis DROs, (which was a great move), but I have just noticed slight lateral play in the spindle accompanied by a slightly different rumble when it’s running. I suspect the bearings but I’m a bit wary about attempting to dismantle the assembly. Can anyone give me any advice please?
      #20128
      Chris Taylor 3
        @christaylor3
        Advice on Spindle Assembly
        #528892
        Chris Taylor 3
          @christaylor3
          Obviously not a rivetting topic so I might as well just offer my own feedback. I dismantled as much as I could to get to the spindle bearings but I could see no way of extracting the spindle assembly without removing the head and control box. So I just cleaned as much as possible, greased the lower bearing and reassembled. Much to my surprise the noise is much reduced and the play has gone. I suspect the grease is responsible for the noise reduction and re-tightening the castle nut at the top for the elimination of play. I don’t really understand the latter because the bearings are just the plain type, and I didn’t expect the pre-load to have any effect on lateral play.
          I’ve read the other threads and looked at the suggested videos but they don’t show the actual dismantling. At some point, I would like to strip the whole spindle down, but looking at the assembly diagram I can’t see how the shaft can be removed without a full strip down because the pair of high/low gears would foul each other.
          I would appreciate any advice from anyone who has experience of this particular mini-mill.
          #528959
          Ketan Swali
            @ketanswali79440
            Chris, perhaps parts of this article may help. To the best of my knowledge, your machine may be the old X2 mini-mill.
            Also, if you search what you are looking for under X2 mini-mill, you will probably find more dismantling information.
            Very broadly speaking, the X2 Mini-Mill head assembly is also very similar to old SIEG C2 and C3 mini-lathe headstock, sharing many of the same components except the spindle. So perhaps also review parts of this guide.
            Ketan at ARC
            #528979
              Ketan to the rescue … like the 7th Cavalry
              Chris Taylor 3
                @christaylor3
                Ketan, many thanks for that, I hadn’t realised that the mills were effectively the same, the article will be carefully studied and I have actually considered converting to belt drive so that’s a bonus.
