Changing grinder wheels for different size – advice required
Home › Forums › Workshop Tools and Tooling › Changing grinder wheels for different size – advice required
  • #160408
    Chris Veitch
      @chrisveitch14689
      I'm hoping to change one of the standard Aluminum Oxide wheels on my bog-standard B&Q bench grinder for a Silicon Carbide wheel for grinding carbide tools. However the originals are 150 x 16mm on a 1/2" spindle whereas the only Silicon Carbide I can find are 150 x 20mm, although there's plenty of room within the housing for a thicker wheel.
      Are there any risks associated in substituting a larger wheel of this size? (Or any other advice on the subject for that matter)
      Chris
      #17465
      Chris Veitch
        @chrisveitch14689
        #160411
        Ian P
          @ianp
          Sticking my neck out here….. but not a lot more expensive is to go for a diamond grit wheel.
          The difference between diamond and green grit is the same as chalk and cheese!
          Diamond even on a metal hub is probably going to be lighter than solid grit.
          Ian P
          #160412
          donkey
            @donkey
            All good as long as you get the full nut on the shaft.
            #160416
            jason udall
              @jasonudall57142
              Apart from the usual safety advice re. hanging a new wheel.
              Green grit wheels “shed”more than uusual. .its part of how they work…
              So are particularly dusty..
              Bonded diamond wheels (for carbide) cut better and cleaner. Don’t need truing (can’t be trued, so get the bushing right)..
              I would still ring a diamond wheel but then though I have seen the result of a wheel bursting I have never heard of a diamond wheel bursting…
              #160422
              stan pearson 1
                @stanpearson1
                Chris
                The only things to look out for are
                Speed rating on wheel is same or lower then grinder, this is more a problem with larger diameter.
                Make sure you put paper packing's ether side of washers don't over tighten and make sure of a full nut.
                Make sure the rest is no more than 1/16" from stone.
                You might have to trim the new stone as to balance them.
                Stan
                #160434
                Eric Cox
                  @ericcox50497
                  "Speed rating on wheel is same or lower then grinder". Don't you mean the speed rating of the wheel has to be the same or higher than the grinder?.
                  #160479
                  stan pearson 1
                    @stanpearson1
                    Sorry Eric
                    Just trying to catch you out ! .
                    Yes speed on wheel same or higher than machine.
                    Stan
