Hi Chris ,
I could show you how to do the calculation that full sized designers used but in truth for a model there are so many indeterminates that the result would not be very accurate .
I suggest that you do two things instead of calculations :
(1) Get information about steam brake cylinders on successful model designs and adapt and modify to suit your specific needs .
(2) Copy the principles and general dimensions of full size steam brake systems .
Notes :
Typical full size steam brake cylinders usually had bores in the range 4 inches to 9 inches .
Taking the larger size that becomes 9/16 to 5/8 inches for a 3 1/2 inch gauge engine and
3/4 to 7/8 inches for a 5 inch gauge engine .
Some full size engines had two steam brake cylinders – one each side and these were usually smaller .
The success of steam brakes in a model depends very much on the design of the brake valve .
MW
Edited By MICHAEL WILLIAMS on 02/02/2012 13:56:03
