Check the back and particularly the bottom of the boring bar clear the pilot hole as it enters, and only the cutting edge makes contact. This much taper says the tool is moving, possibly being pushed aside as it enters the pilot hole.
If the boring bar is too big (or the hole too small) you can find that the leading edge cuts Ok because the frohnt clearance of the tool guarantees thatt the cutting edge makes contact first. Result, nice pretty sweetarf and all is well until the tool enters further, now the bottom of the tool rubs and the cutting edge is no longer the only touch point of the tool with the work.
Give away symptom is an absolutely horrible surface finish in the hole, tapered so the hole is narrower the deeper it goes.
If you've got the opposite taper, do let us know. No theories yet, but I'm working on it
Edited By Simon Williams 3 on 18/11/2017 23:31:44
Edited By Simon Williams 3 on 18/11/2017 23:32:40
Sorry about multiple edits, predictive text…….
Edited By Simon Williams 3 on 18/11/2017 23:34:00
