Bloodhounds wheels go on the lathe
Home Forums Beginners questions Bloodhounds wheels go on the lathe
  • #183295
    Ady1
      @ady1
      #7521
      Ady1
        @ady1
        #183297
        KWIL
          @kwil
          According to The Engineer magazine thay have also tested the composite "armour" to ensure that should any wheel shed a slug of aluminium it does not penetrate the cockpit, it did not.
          Wheels are forgings to ensure the grain is radial, like spokes, for max strength.
          #183299
          martin perman 1
            @martinperman1
            My Brother and I made small donations a couple of years ago and we get regular news letters via email that make interesting reading on how the project is going.
            Martin P
            #183302
            Nick Grant
              @nickgrant21535
              The bearings must be quite something to cope with that!
              #183313
              pgk pgk
                @pgkpgk17461
                Posted by Nick Grant on 15/03/2015 13:12:17:
                A jet engine does around 10K rpm, a dental turbine to 500K rpm and Trust is panning on wheels at 10.5K RPM so perhaps not such a biggie…
                What percentage of drive goes through the wheels.. or ar they just there to stop the chassis scraping…?
                #183315
                martin perman 1
                  @martinperman1
                  This car has three engines, the jet to power the car up to a certain speed the rocket to assist through 1000 mph and a ford cosworth whose sole job is to power a pump to supply fuel to the rocket, no drive goes through the wheels.
                  Martin P
                  #183316
                  Nick Grant
                    @nickgrant21535
                    Posted by pgk pgk on 15/03/2015 13:53:28:
                    True but surely wheel bearings would be taking a far greater load than either of those? I was thinking you would need a huge amount of downforce to keep this thing on the ground at those speeds.
                    #183318
                    Swarf, Mostly!
                      @swarfmostly
                      Hi there, all,
                      I worry about projects like this one! I'm sure I read somewhere that one of the earlier (1930s?) land speed record attempts failed because the driver attempted to steer the car at speed – the gyroscopic effect resulting from the high RPM of the high moment of inertia wheels caused the yaw moment (steering) to be transposed to a roll axis moment (precession) which turned the car over.
                      How have more recent attempts addressed this problem?
                      Best regards,
                      Swarf, Mostly!
                      #183319
                      martin perman 1
                        @martinperman1
                        I just been and had a look and the wheels are designed for 10,500 rpm.
                        Martin P
                        #183320
                        Phil Whitley
                          @philwhitley94135
                          Pendine sandsm, J G Parry -Thomas? http://en.wikipedia.org/wiki/J._G._Parry-Thomas
                          Phil
                          #183328
                          KWIL
                            @kwil
                            Jet engines run at rather more than 10K rpm. A model turbine runs in excess of 100K rpm and they certainly do not self sustain until around 25/30K rpm and then they spool up from there.
                            #183331
                            pgk pgk
                              @pgkpgk17461
                              Posted by Nick Grant on 15/03/2015 14:31:07:
                              I'd have though the whole point of downforce here is just to prevent lift from flipping it over – as opposed to pinning drive wheels to the ground. So while there will be aspects of bunce and buffet on the smoothest terrian they can find I'd expect th downforce to be less than first guesses might suggest – or it'll end up a two deep scars across the sand and four flat bottom wheels
                              Surpersonic speeds do very weird things to centres of pressure over surfaces. Fastest i ever piloted was a single engine prop job in some basic aerobatics. Six times as fast in experimental stuff is nutter territory.
                              #183332
                              John Stevenson 1
                                @johnstevenson1
                                End of the day these people will some some real experts advising them.
                                They won't be using forums for guesswork advise no matter how well educated the guesser feels they are wink
                                #183339
                                Nick Grant
                                  @nickgrant21535
                                  Posted by John Stevenson on 15/03/2015 17:03:11:
                                  I don't see anyone trying to advise, just a general appreciation of the engineering involved and how difficult and dangerous it will be.
                                  Rather patronising to suggest anyone here would think we know better than the guys and girls doing the work to be honest.
                                  Edited By Nick Grant on 15/03/2015 17:51:44
                                  #183341
                                  JA
                                    @ja
                                    I visited the project last autumn and went to a lecture on Thrust SSC after its successful record breaking attempt. Essentially the people who worked on Thrust SSC are now working on Bloodhound so there is a good continuity of knowledge. However, when questioned, their spokesman did not think they would work on another project because they were getting old.
                                    Thrust SSC did have a problem after it went above Mach 1 – the external shock waves lifted the surface of the salt lake ahead of the wheels. This is now well understood and should not be a problem.
                                    Comments on bearings – helicopter gas turbine bearing speeds can exceed 30,000 rpm. Gas turbine bearings have a completely different set of problems to high speed wheel bearings – the loads on the bearing are very low which can lead to skidding of the balls or rollers and the environment can be very hot. Great care is taken to cool the bearings at the hot end of an engine so that the oil lubricating the bearing does not catch fire.
                                    If you get the opportunity of visiting the project it is well worth going. However I believe visits may soon curtailed to allow assembly of the car.
                                    JA
                                    #183382
                                    Ady1
                                      @ady1
                                      …but not too much or you turn the car into a plough…. while too little means she flips front over back
                                      Presumably they have some sort of dynamic spoiler system, still one heck of a challenge though, especially at 1000 mph
                                      #183400
                                      blowlamp
                                        @blowlamp
                                        I don't want to be a killjoy, but this looks too dangerous for my liking and I fear for the pilot's life. Surely a pilotless car would be the same great challenge for the engineers without the huge risk to someone's safety?
                                        There just doesn't seem to be any margin for error at that speed.
                                        Martin.
                                        #183405
                                        Ady1
                                          @ady1
                                          That's the challenge, they've taken 20 years between Thrust SSC and Bloodhound for another 250mph
                                          Bloodhound will go faster than any passenger plane ever built, only concorde and concordski have gone faster
                                          Reading the comments on the BBC site it looks like most people just don't realise how big a challenge this is
                                          It's going to be a nailbiter
                                          #183408
                                          Ady1
                                            @ady1
                                            They've taken Colin Chapmans advice: "just add lightness"
                                            This new car is 4 tonnes lighter than Thrust SSC
                                            #183421
                                            JA
                                              @ja
                                              Posted by blowlamp on 16/03/2015 10:00:37:
                                              Martin.
                                              After the War the government ordered a supersonic development aeroplane from Miles, the M52. Half way through its construction they got cold feet about putting a pilot through the "sound barrier" so they cancelled it and instead messed about with rocket powered models. The result was that we, the British, introduced into service our first true supersonic aircraft (that is in level flight) about eight years after the Americans and six years after the Russians.
                                              The really sad thing is that the M52 would have worked.
                                              JA
                                              #183426
                                              Chris Trice
                                                @christrice43267
                                                Down force in this car only has to be enough to stop it lifting. Downforce is more usually about having the tyres maintain grip on the tarmac particularly when cornering.
