BH600G Fine Feed Help
Home › Forums › Help and Assistance! (Offered or Wanted) › BH600G Fine Feed Help
  • #224804
    Steve Cole 1
      @stevecole1
      So finally got around to turning that back plate down that my collet chuck is mounted to and as a result the cast iron went everywhere! So i have cleaned my lathe down and its spotless again, whilst i was doing it i thought i would do some basic up keep, oil re greasing and checking everything is in good working order.
      Now as some of you may know i want to do a screw cutting clutch modification and sort out my gear ringing. Looking around i can see some people have fitted a direct belt drive, others have changed there gearing but not a lot has been written. What i would like is to reduce the feed rate as its slightly course and re mesh the gears to shut that ringing up. Failing that i would also consider driving the feed directly off the head however how could i work out the dimensions of the pulleys in order to reduce the feed rate? thinking
      #32649
      Steve Cole 1
        @stevecole1
        #225002
        Bazyle
          @bazyle
          I think what you are planning is to put a pulley on the spindle or preferably on the first shaft after the tumbler reverse, and another pulley on the input to the gearbox. the finest feed on the BH600 is about 4.7 thou per rev.
          To work out the relative sizes of the pulleys you first need to work out the ratio of the gearing that normally connects spindle to input shaft. Luckily on the BH600 I think that is 1:1. Therefore you can easily reduce it by a 1:2 or 1:3 ratio.
          Pulleys provide a ratio in proportion to their relative diameters but for this you would probably want to go for toothed belts which will be just as quiet as smooth belts so it is just a case of selecting appropriate tooth counts.
          toothed 'timing' pulleys
          #225028
          Dave Martin
            @davemartin29320
            Steve,
            If you haven't already seen it, have a look at this thread on a belt conversion – lots of useful real-world info from "Earl John".
            Howard Lewis
              @howardlewis46836
              My lathe is a Engineers ToolRoom BL12 /24, which other than having metric leadscrews, dual dials, and different paintwork, is virtually the same as the BH600.
              To produce a finer feed rate, I made a 80T gear to replace the 40T on the input to the Norton box.
              From memory, the gears are 1.5 Mod.
              This then means that the closing arrangements for the Gear Cover have to be modified.
              On my lathe, sadly, to remove the closure fitment from the cover I had to destroy the composite knob.
              (Fortunately, a suitable replacement was available,) A new tapping had to made into the Norton gearbox casting, and a fresh hole drilled in the Gear Cover, to match. But it works. With the gear train set to 40T : 127/120T : 80T, and the gearbox set to to E 8, my calculations suggest a feed rate of 0.00225"/rev.
              The tumbler gears were noisy on mine, so eventually, they were replaced by nylon ones. If memory is correct, the two cost £41 from Davall Gears!
              Obviously, if the gears are meshed too tightly, they will be noisy, not to mention being more prone to wear. Backlash is set by trapping a piece of paper in each mesh, before tightening the fixings. This should give about 0.003" of backlash, after the paper has been removed.
              The big compound gear is, I suspect, the source of the ringing. The holes in it SHOULD reduce sound radiation, but I wonder if filling the holes with lead would be a means of deadening the sound further? Because this would increase the inertia, and so possibly reduce sped variation, this may also contribute to noise reduction.
              Lubricating the gears with a really thick grease helps to lessen the noise, very slightly. (I was given some specialised gear lubricant which is really gooey!)
              Hope that this may be of some help.
              #225219
              Steve Cole 1
                @stevecole1
                Excellent advice! Thank you all for your input, i shall report back with what i have done. 1st thing 1st is curing a leak which i have found thinking should be a simple enough job. Then its onto my conversion, i think geared belts and delrin tumblers are the way forward. I don't really want to start modifying the housing if i can help it.
                Steve
                #225225
                Howard Lewis
                  @howardlewis46836
                  If you are worried about repositioning the stud, it is only a M8 tapping, and a matching hole in the sheet metal cover, large enough to take the fitting.
                  It might be worth making a knurled metal knob, before hand, just in case, like me, you destroy the composite one.
                  #225412
                  Howard Lewis
                    @howardlewis46836
                    My memory failed! For anyone contemplating halving the feed rate.
                    The backgears are 1.25 Mod. (Looked at the cutter and its the only Mod cutter that I have, so for once, must have got it right)
