Best PTFE. for rings Virgin or filled, carbon/grahite
Home › Forums › General Questions › Best PTFE. for rings Virgin or filled, carbon/grahite
  • #464146
    Chinkoa
      @chinkoa
      Which is best PTFE. for inlet Steam Bobbins rings. Virgin, Filled Carbon PTFE, or Graphite filled PTFE?
      For the amount of use it will get I am leaning towards the Virgin variety.
      What sizes and clearances for a 15/16 Dia. Bore? Diameter, Width and thickness.
      I am thinking of fitting two rings insame groove and making the total width the same as the inlet port (1/4&quot 2 x 1/8" wide rings.
      Colin
      #27281
      Chinkoa
        @chinkoa
        Rings for inlet Steam Bobbin
        #464156
        Simon Collier
          @simoncollier74340
          That is a vexed issue. The high expansion of PTFE with temperature is very problematic. The bore needs to be honed to a very good finish or the PTFE will wear very quickly. Fluoroscint, which is mica filled I think, would be my pick but it is very expensive. It's thermal expansion is 1/3 that of virgin and in the order of that of aluminium. If at all possible, I would use conventional valve rings.
