Best mini grinder bits
Home › Forums › General Questions › Best mini grinder bits
  • #24457
    michael cole
      @michaelcole91146
      #231749
      michael cole
        @michaelcole91146
        I have a dremel type mini grinder. I use it either to grind surfaces ,like cleaning up a casting or to clean up the egde of thin sheet. I just cut some 1.2 mm SS sheet.
        Do you perfer the sanding drums or to use a stone? I find that the stones i use are very soft and wear away quickly. Does anyone have good results with the tiny milling cutters type?
        #231750
        roy entwistle
          @royentwistle24699
          Try the diamond bits
          #231754
          Hollowpoint
            @hollowpoint
            You want the orange aluminium oxide grinding wheels. Forget the cheap ones get the proper dremel branded ones. They last about 4-5 times longer. I like the 952 cone shape best.
            Edited By Hollowpoint on 26/03/2016 10:55:35
            #231763
              Posted by Hollowpoint on 26/03/2016 10:54:14:
              That's what I tend to use on castings, linisher is quicker on sheet material edges.
              #231773
              michael cole
                @michaelcole91146
                Posted by JasonB on 26/03/2016 12:20:42:
                But I am cleaning up the inside edge of holes on sheet steel, Linisher will not work.
                #231810
                speelwerk
                  @speelwerk
                  Not cheap but also very good is **LINK** , it is more difficult to control those tiny milling cutters by hand.
                  Niko.
                  #231813
                    I prefer the emery drums for cleaning castings, with a diamond burr for tight corners
                    I suspect this is very much something that is personal preference and the type and size of casting you usually use.
