Axminster cq6230 lathe
Home › Forums › General Questions › Axminster cq6230 lathe
  • #464860
    Robert Askew
      @robertaskew15193
      anyone on here got an Axminster CQ6230 lathe
      having trouble screw cutting
      i normally only cut metric threads no problem but today wanted to cut imperial
      but come unstuck as looking on chart on machine I don’t have a gear Z or position Z on gearbox
      #27288
      Robert Askew
        @robertaskew15193
        Screw cutting
        #464865
        ega
          @ega
          Don't know the lathe but "Z" is normally an abbreviation for number of teeth (from the German Zahl for number).
          #464870
          Howard Lewis
            @howardlewis46836
            It is possible that the same lathe, in another colour scheme is imported by someone else, and details for that machine, whatever it may be, could be of help.
            By the looks of what is shown on Google, in the Axminster Operator Manual, there may well be something similar in the Warco or Chester range.
            Unfortunately, the manual, on page 17 /18. refers to using the controls to cut threads, but there does not seem to be a table of threads and the settings to cut them.
            It will mean comparing specification details to find an equivalent machine, and then to search for a thread cutting chart for that machine.
            #464878
              Hi Robert,
              Can you post a readable photo of the gear settings chart stuck on the front of the headstock?
              Mine identifies 4 'Z' positions – it means the axles on which change gears are mounted as necessary to achieve threading ratios. I guess your chart is trying to impart the same information, and all we have to do is crack the code.
              Robert Askew
                @robertaskew15193
                This is the lathe
                #464893
                  lathe should have come with some change gears, Z is the gear on the end of the gearbox input and needs changing to the one that corresponds with teh tpi you want to cut then set the knobs to suit
                  #464895
                  Robert Askew
                    @robertaskew15193
                    Thanks for that makes sense now
                    and I have found the gears
                    must have had a senile moment
                    #464898
                      Also not that the first row uses a 24T as the first gear and the second row 48T
