Arrand facemill TORX size..
Home › Forums › Workshop Tools and Tooling › Arrand facemill TORX size..
  • #427280
    Alan
      @alan14594
      I've managed to lose the TORX key for my Arrand Facemill…
      Would anyone know what size I need to get please..??
      The inserts are TCMT 110204…
      Thanks!!
      Alan
      #19451
      Alan
        @alan14594
        #427330
        Vic
          @vic
          If it’s an M2.5 screw then I think it’s a T8. I find screwdriver type better than flag style drivers and are harder to mis place!smiley
          #427362
          Brian Wood
            @brianwood45127
            Hello Alan,
            The correct key is T7.
            I have a spare I can post to you if you wish, send me a PM
            #427376
            Alan
              @alan14594
              Thanks Brian!
              PM sent…
              Alan
              #427385
              Vic
                @vic
                That’s odd, the TCMT 1102 seems to have a 2.8mm hole through it so should take an M2.5 screw?
                I have several tools that use M2.5 Torx screws and the driver for them is T8.
                If it does turn out to be a T8 Alan I’ve got several T8 Flag style drivers I don’t use so you’re welcome to one.
                I have a “Little Hogger” set of milling cutters that I got from Chronos and one of those takes inserts that look like TCMT inserts but are a little thicker I think. I’ve only ever got replacement inserts from Chronos and these use an M3.5 Torx screw that requires a T15 driver which comes with the set.
                #427387
                Vic
                  @vic
                  This is quite interesting. I have a large selection of Torx insert screws ranging from M2.5 up to M6. I have several lengths of the M2.5 screws and having just checked they all take the Torx T8 driver.
                  Looking some more though I found there are some M2.5 screws with a smaller head that take the T7.
                  Which tools take which screws however remains unclear!
                  #427393
                    Different inserts can have different angled CSK holes so a steeper CSK needs a smaller head and therefor smaller Torx. Also varies between make, my Glanze ones are all T8 but I have others that need T7
                    Although the little hoggers has a CSK screw the inserts are not countersunk and they have no chipbreaker so are not ***T more like TCMA
                    #427397
                    Vic
                      @vic
                      Yes I noticed that from the APT site Jason. I do have a T7 driver but I’ve never required it. All my tools with M2.5 Torx screws are T8.
                      Jason, are there any suppliers you recommend for the little hogger triangular inserts?
                      #427399
                        I don't use mine a lot and have only bought then from Glanze/Chronos though last time I ordered they were OS of teh shape I wanted.
                        #427407
                        Brian Wood
                          @brianwood45127
                          I did try my T7 flag style driver on the screws in my Arrand face mill before offering it to Alan, but from what Vic says there is clearly some degree of variability in the fit in the heads on screws of this size.
                          Perhaps Alan should also equip with a T8 driver to cover all the bases!!
                          #427421
                          Alan
                            @alan14594
                            I 'THINK' that I have a T8 driver…
                            It fits the glanze tools for the lathe… But its too large for the facemill…
                            Alan
                            #427446
                            Vic
                              @vic
                              I’ve got a spare T8 if you need it Alan. I bought a pack of them to give to friends with some tools I made for them.
                              #427447
                              Vic
                                @vic
                                Posted by JasonB on 04/09/2019 13:47:05:
                                Apparently it’s a TNMA 1103 according to Chronos.
                                #427449
                                Brian Wood
                                  @brianwood45127
                                  In the light of this correspondence, I tried a T8 driver on the Torx screws in my Arrand face mill this afternoon; it was too big as he too has discovered.
                                  Regards Brian
                                  #427583
                                  Vic
                                    @vic
                                    Just to confuse things some companies like Sandvik use Torx Plus screws on their tools. They are designated IP for Internal Plus on the drivers. Screws and drivers are said to be not interchangeable with regular Torx. Picture here:
                                    Alan
                                      @alan14594
                                      Thank you Brian!
                                      TORX key has arrived, and as it says 7 on the flag,
                                      and fits the screw snugly,
                                      the size for the Arrand facemill is a T7…
                                      Inserts turned… and job finished!
                                      Alan
                                      #427792
                                      Brian Wood
                                        @brianwood45127
                                        That size also fits the TORX screws on the carbide tooling that Arrand used to sell many moons ago; they too had the same size of tip ( TCMT 110204)
