Annealing sheet brass
Home Forums Beginners questions Annealing sheet brass
  • #183542
    Peter Simpson 1
      @petersimpson1
      I have just purchased 1.5mm brass sheet to make side tanks for my 5" gauge Speedy. Should I anneal this prior to bending the 3/8" radius bends.
      #7528
      Peter Simpson 1
        @petersimpson1
        #183554
        Nigel Bennett
          @nigelbennett69913
          No. If you do, you'll end up with Pringle-shaped brass sheet. It will really soften it and it'll be much more difficult to get the flat bits flat again. There'll be no strength to it!
          3/8" rad should bend well in the "half hard" state that brass sheet is normally supplied. Try it out on a bit of scrap first (assuming you've got some!)
          Good luck – and remember to measure twice before cutting once….
          #183557
          Speedy Builder5
            @speedybuilder5
            Peter, how about some photos of SPEEDY, there are a few of us building this one again.
            BobH
