An odd source of corrosion identified ?
Home › Forums › Hints And Tips for model engineers › An odd source of corrosion identified ?
Viewing 15 posts - 1 through 15 (of 15 total)
  • #301819
    Tim Stevens
      @timstevens64731
      I have come across fine rust films on one or two newly made steel parts (carefully stored away in my dry workshop), while other stuff in the same drawer was unaffected, and I wondered what was the cause. Recently I made a steel spacer with a polished surface, and cleaned it of polishing debris in my usual way, with a solvent from a spray can of 'brake cleaner'. A few moments later, as I watched, it was hazed over with a very thin brownish film – the dreaded rust, again.
      What happens is that the solvent has two effects as well as removing dirt. It removes every trace of grease or oil (which is what you want with a brake cleaner), and as it evaporates it lowers the temperature of the workpiece. This drop in temperature causes condensation, if the day is fairly humid, and there is no trace of protection on the bare metal. Small parts are cooled most, so are most vulnerable. The rust that is produced is very fine and thin – but it could seriously mark a finished tool surface or one on a display model.
      The answer, I suppose, is a final quick squirt with an oil product, followed by a thorough wipe, which should leave a thin invisible film of oil and so stop any condensation reaching the bare steel.
      Best wishes to y'all,
      Tim
      #30619
      Tim Stevens
        @timstevens64731
        Degreasing solvents
        #301846
        Breva
          @breva
          Thanks Tim. Good to know that.
          Hopper
            @hopper
            I'm a great believer in WD40 – solvent, cleaner, lubricant and preservative all in one. And water displacer too.
            #301855
            Speedy Builder5
              @speedybuilder5
              As apprentices, some of us had dry hands and some had rusty hands. I guess its similar to a dry workshop in a dry atmosphere or a dry workshop with a humid atmosphere.
              BobH
              #301874
              roy entwistle
                @royentwistle24699
                Hopper Gummer up of brass as well, Particularly on clocks
                Roy
                #301876
                Brian Wood
                  @brianwood45127
                  Rather similar effects are noticeable on sand blasted surfaces, they too are very vulnerable to immediate corrosion afterwards.
                  #301880
                  Hopper
                    @hopper
                    Posted by roy entwistle on 10/06/2017 09:15:15:
                    Roy
                    Guilty as charged, sir. But I don't mess with clocks or ammo. The WD40'd brass sector arms and knobs on my Versatile Dividing Head have remained a bright shiny brass finish since I made them late last year, through the tropical monsoon season here by the coast. Good enough for me.
                    #301980
                    vintagengineer
                      @vintagengineer
                      Another cause is that all solvents contain water in varying degrees. That is why cheques have a water based colour wash to stop people using solvents to alter them.
                      #302029
                      I.M. OUTAHERE
                        @i-m-outahere
                        Maybe dunk them in metho after using brake cleaner ?
                        I have used that after using rust converter which needs to be wiped over wth a wet rag to clean off on car panels as it pulls the moisture away from the steel .
                        That reminds me i need to recharge my moisture absorbent units !
                        Ian
                        #302037
                        Bazyle
                          @bazyle
                          Warm part with hairdryer before final stage to compensate.
                          At least one air crash in the 'fifties was attributed to perspiration corroding some wire in a servo. ( I heard this in a lecture at university so might be folklore but not internet fake news)
                          #302045
                          John Gardener
                            @johngardener91897
                            Posted by Hopper on 10/06/2017 10:21:20:
                            Roy
                            He who oils his ammo will soon deactivate his firearm!
                            #302068
                            Speedy Builder5
                              @speedybuilder5
                              Bazyle
                              Many 'Air Accidents' have been caused by inspectors leaving torches and mirrors behind them after an inspection! We had a Vickers Valiant return to Weybridge for major repair as the pilot's urine had spilt out of the bottle and corroded the structure.
                              BobH
                              #302077
                              vintagengineer
                                @vintagengineer
                                When I did my firearm training in South Africa, we were taught to regularly unload the magazines on our weapons and reload them to make sure there was no crap or jammed rounds in the magazine. Never heard of oiling ammunition.
                                Posted by John Gardener on 11/06/2017 09:39:31:
                                Roy
                                #302099
                                John Gardener
                                  @johngardener91897
                                  I worked for the NRA and once had a customer blow up his rifle because, as an air rifle shooter, he had oiled his pellets to give him extra power and flatter trajectory.
                                  Despite advice and warning to the contrary, he oiled .303 bullets to shoot through his Enfield Number Four.
                                  He was lucky not to lose something, finger, eye – life even.
                                  Apologies for going off track
