Am I being too gentle milling?
Home › Forums › Beginners questions › Am I being too gentle milling?
  • #237676
    Rod Neep
      @rodneep80388
      A *raw* beginner milling question (so be gentle)….
      I used my new milling machine (SIEG X2P) for the first time this evening, basically to cut a 6mm slot 6mm deep in a piece of 4mm thick mild steel.
      Being cautious, I feel that I "nibbled" at it with the 6mm end mill, and took too many passes to reach the depth of the slot. How deep a pass would be "sensible"? (i.e. how many passes?)
      Thanks
      Rod
      #8121
      Rod Neep
        @rodneep80388
        #237677
        daveb
          @daveb17630
          Depends on your milling machine, you don't want to take too heavy a cut with the smaller ones, motors and controllers can go pop! I would probably do this in 3 cuts but my machine is fairly heavy with no fragile electronics. If the cutter is cutting without making horrible noises then it should be OK. A squirt of oil helps. Harold Halls book on milling is worth getting if you don't already have it. Don't worry too much about weather you are doing it 'properly', time isn't too important for hobby work, it's the result that counts.
          mechman48
            @mechman48
            Not having knowledge of this machine I would of thought that 2 x 3 mm or 3 x2 mm cuts would have been feasible in that piece. To much ' nibbling' will end up with your cutting edges rubbing rather than cutting & becoming dull very quickly. As you get to know your machine you will be able to 'feel & hear' what your machine is capable of.
            Cheers
            George.
            #237683
            Frances IoM
              @francesiom58905
              ?how do you cut 6mm deep in a 4mm bar ?
              It’s usually easier to cut slots with slot drills rather than endmills unless you want a slot open at one end. Endmills as you have probably found will not bore a hole as the cutting face does not include the middle third of the end.
              Edited By Frances IoM on 05/05/2016 23:05:49
              #237684
              Rod Neep
                @rodneep80388
                Posted by Frances IoM on 05/05/2016 23:05:24:
                Well, I managed to. See the photo above.
                thinking
                #237685
                  Frances,
                  I think the picture that Rod posted answers that ^^^
                  Edit: You beat me to it, Rod.
                  Edited By Michael Gilligan on 05/05/2016 23:12:42
                  #237691
                  Rod Neep
                    @rodneep80388
                    Well….. I compromised, still being cautious, and took 1mm cuts on the second one I needed to make. The machine and the cutter didn't complain, and the revs stayed consistent on the display.
                    One thing which I noticed, is that on the "exit" side, there was a pretty large noticeable burr on the edge of the steel.
                    Thanks for your help folks. Much appreciated. Maybe I will be a little more brave next time I need to do a similar task, and take 2mm cuts.
                    Rod
                    Edited By Rod Neep on 06/05/2016 01:13:17
                    #237697
                    Ed Duffner
                      @edduffner79357
                      Hi Rod,
                      I'm relatively new to machining and have a Warco WM-16 milling machine which I think is the same size or maybe just a little larger than the X2P. It has a 2MT spindle and 750W motor.
                      For a long time I've been using end mills and the occasional 2-flute slot drill from kit inherited from my Dad and have always taken very cautious milling cuts.
                      I noticed Jason.B mention the other day about trying out a roughing endmill from ARC and I've always wondered what these were like so I bought a 10mm HSS-AL 4flute and I have to say I am amazed at how much more metal I felt comfortable removing in a single pass, this was tried on EN3B mild steel to make some T-nuts. It also feels different when winding the axes, seems to have more feedback through the winding handles.
                      I would highly recommend anyone new to hobby machining to invest in at least one roughing endmill as it turns what can be a tedious exercise into an enjoyable step in making something on smaller milling machines. Wish I'd done this sooner.
                      Ed.
                      Edited By Ed Duffner on 06/05/2016 06:20:22
                      #237701
                        A simple rule of thumb when using the full width of the cutter is 1/4 of the diameter so 4 passes of 1.5mm, use that as a starting point and go up or down depending on the machine. One other thing to watch if you were using a 4-flute end mill is that the more it has to remove in one pass the more the cutting action will pull it to one side so you could end up with a slot wider than 6mm.
                        Feed rate wise again don't tickle it, about one turn of teh handwheel per second would be a reasonable starting point
                        One other thing, that black coating on the hot rolled bar is not kind to cutting edges
                        J
                        Edited By JasonB on 06/05/2016 08:17:33
                        #237707
                        Frances IoM
                          @francesiom58905
                          Ah! I see – I generally browse with images turned off and have to explicitly allow any redirects (avoid many problems including blocking the all too many trackers) thus I hadn’t realised you had published a photo hosted from your own site
                          #237719
                          Rod Neep
                            @rodneep80388
                            Posted by JasonB on 06/05/2016 07:38:10:
                            J
                            Great information for me. On all points. Thanks!!
                            I really appreciate that information.
                            Rod
                            #237725
                            Anonymous
                              On the vertical mill I'd cut the slot in two or three passes with a 6mm cutter. On the horizontal mill straight through in one pass.
                              With these small cuts you are unlikely to be power limited, even on a small mill. I'd concur with JasonB; the biggest mistake is pussyfooting around with feedrates. Slower isn't better, it just rubs the cutter and squeals or chatters.
                              #237730
                              John Rudd
                                @johnrudd16576
                                To be even kinder to your machine/cutter, you could have removed the bulk of waste by hand……in this instance..cheeky
                                Hacksaw springs to mind…..
                                #237754
                                Rod Neep
                                  @rodneep80388
                                  Posted by John Rudd on 06/05/2016 10:24:34:
                                  Indeed wink you are perfectly right….
                                  And I am quite capable of cutting and filing a 6 x 6mm slot in the edge of that metal, especially as there was no need for fine tolerances in this case, as it is a clearance slot. (A pair of clamping plates).
                                  But I have a new toy! And I wanted to use it. cheeky
                                  It is all part of the learning process.
                                  Cheers
                                  Rod
                                  #237761
                                  Muzzer
                                    @muzzer
                                    Looking at Ketan's recent post about mini mills, it seems the SX2 has a brushless motor rated at around 500W mechanical (shaft) power. That's pretty respectable and should be capable of shifting some metal.
                                    You should get yourself a decent block of mild steel and do some experimentation to get a feel of what are the limitations. You shouldn't be able to blow up the drive and the worst you can do is break a few cutters. You might be surprised what can be achieved.
                                    There are plenty of free machining calculators out there – and a few paid for ones if you insist. They will tell you what maximum feed rate, depth of cut etc the cutters can tolerate, so you can use them to put a ceiling on what you try but within those it's the machine that will limit performance. What have you got to lose?
                                    Get half a dozen cutters in and be prepared to sacrifice some of them in the name of learning – and try a roughing cutter, as suggested above. Go on!!
                                    Murray
                                    #237896
                                    Dan Carter
                                      @dancarter89683
                                      Rod,
                                      I just tried the cut you made with a 6mm 4 flute ripper cutter on my old style x2 (the one with the tilting column).
                                      Went through in one pass, 6mm deep without any significant complaining.
                                      Dan
                                      #237903
                                      Mick Henshall
                                        @mickhenshall99321
                                        Seeing Ed seems pleased with Arc's roughing end mill I have just ordered one and looking forward to trying it on my wm14
                                        Mick
                                        #237905
                                        Rod Neep
                                          @rodneep80388
                                          Thanks folks. This machine is obviously capable of more than I thought. surprise
                                          Rod
                                          #237912
                                          Roy M
                                            @roym
                                            This may sound counter intuitive, but depending upon how much value you attach to your cutters, another approach would be to lay the plate flat,(as for drilling), and then use the very top of your cutter to cut the slot leaving a full rad on the bottom to be removed on a second setup. The reasons for this approach are that you get to use the part of the cutter seldom used(the top bit), thus minimising cutter flexing and preserving the bottom portion for creating square accurate corners. The life of cutters or lathe tools is measured by the time the tool is actually in cutting, so if you take three cuts, then, in theory, it will wear out three times quicker. Once the edge has gone, cutter flexing and poor size and finish will result. Roy K.
                                            #237918
                                              Although the rougher/ripper may go through in one pass if the work needs a good finish you will have to go through with a normal cutter to clean up the edge so choose your cutter diameters accordingly to allow for a finishing cut.
                                              Have a look about 2/3rds down this page where I'm milling the cylinder as you can see the rougher in action and the finish it leaves compared to a 3 flute "normal" cutter
                                              #237924
                                              Rod Neep
                                                @rodneep80388
                                                Thanks for that Jason. The whole thing was fascinating breakfast reading.
                                                #238092
                                                Tim Stevens
                                                  @timstevens64731
                                                  The metal you show looks like 'black' steel as used for welding structures. This helps to explain the burrs you noted. I have found inclusions of slag in such material – visible strands about the size of a pencil lead. This is no problem for welders (who tend to cut with shears or angle grinders), but it can wear cutters quickly.
                                                  You might get a better finish and longer tool life if you seek out 'free-cutting bright mild steel'.
                                                  Cheers, Tim
                                                  #238095
                                                  Rod Neep
                                                    @rodneep80388
                                                    Lesson learned, Tim. Thanks.
                                                    That's what I thought I had ordered, but as these pieces were to be just clamping plates I decided to just go ahead with them.
                                                    Cheers
                                                    Rod
