A Self-Feeding Facing Tool
Home Forums Workshop Tools and Tooling A Self-Feeding Facing Tool
  • #17521
      Geometer (Ian Bradley) article reprint
      #165782
        This outline design should be enough to allow experienced hobby engineers to make their own version.
        Full article HERE (subscribers only).
        Edited By JasonB on 06/10/2014 16:45:24
        #165793
        john jennings 1
          @johnjennings1
          Using Firefox, the right hand column is 'behind' the list of forum posts on the right side of the screen.
          The pdf downloads fine
          #165794
            Should be OK now I have resized the image.
            I'll go and alter Neil's spelling mistake now, just can't get the staffsmile p
            J
            Edited By JasonB on 06/10/2014 16:45:07
            #165800
            Bazyle
              @bazyle
              There is also a slightly posher version of this using a cast iron chuck backplate with milled dovetail slide. . I've seen a couple on ebay over the years. I have one which works ok though the heavy slide means it gets a bit unbalanced so a cunning builder might make one with counter moving tool blocks.
              #165811
              Steamer1915
                @steamer1915
                The original article was published in 1960, not 2014.
                Steve.
                #165812
                  Date corrected
