A Real beginners question !
Home Forums Beginners questions A Real beginners question !
  • #7601
    bill james 3
      @billjames3
      #188345
      bill james 3
        @billjames3
        I have just acquired a Myford lathe, it is in working order although I dont know if it is aseven or super seven. Whats the difference?
        Next I reckon I need to service it . It runs. the motor seems OK and it has a suds pump which works.
        It needs a good clean, so to do this obviously I need to dismantle some parts, but before I make any moves in this direction I would welcome any advice from the forum. There is a good selection of tools, an inside and an outside chuck and a four jaw chuck,a couple of faceplates and other bits & pieces
        It was a freebie, so I dont mind spending a bit of money on it to refurbish it.
        All advice is welcome .
        #188347
        Rainbows
          @rainbows
          A free myford? Damn what a way to start out.
          You might want to post a picture of it to get better advice.
          #188348
          Swarf, Mostly!
            @swarfmostly
            Hi there, Bill,
            Welcome to the forum.
            The easy way to tell the difference is to look at the vee-belt that connects the counter-shaft to the lathe mandrel – if it's an ML7, the pulleys are triples, if it's a Super Seven they are quadruples.
            Regarding dismantling, I'd recommend that you postpone that! Get it going and make some swarf first, you may discover you can leave well alone.
            And have a browse on lathes.co.uk.
            Best regards,
            Swarf, Mostly!
            Edited By Swarf, Mostly! on 01/05/2015 23:10:16
            #188351
            Ady1
              @ady1
              Buy a useful book and start reading up, and use the netty to suss your machine tool out
              #188356
              Lambton
                @lambton
                Once you have identified it as an ML7 or a Super 7 buy a proper Myford handbook that covers virtually all you need to know. They are available from Myford or eBay. You can also find free PDF copies on the internet.
                #188359
                bill james 3
                  @billjames3
                  Hello again.. It has 4 pulleys so it is a super 7.
                  Not only that, looking at the cover for the pulleys, it says "SUPER 7" DOH!!!!! !I have used it to do a bit of practice turning on bits of scrap and it does seem to work fine. There is a box with lots of gears which I am told are for screwcutting , these obviously fix into the gearbox on the lewft hand side of the machine.
                  I need to buy a book.
                  #188361
                  NJH
                    @njh
                    Bill
                    This is the bible :-
                    Myford Series 7 Lathe Manual: ML7, ML7-R, Super 7 Paperback – 31 Dec 1998
                    £7.95 from Amazon
                    And worth every penny!
                    Norman
                    #188362
                    mechman48
                      @mechman48
                      Ooooh you lucky b****r a free Myford Super 7 …. face 14 crying if as you say it seems to work fine… leave well alone!
                      remember the adage… 'if it aint broke don't fix it' … just get the info read, & practice, & most of all, enjoy your good luck yes
                      George
                      #188367
                      bill james 3
                        @billjames3
                        Posted by NJH on 02/05/2015 09:10:44:
                        Bill
                        £7.95 from Amazon
                        Norman
                        Done Thanks.
