Thomas from Hornby
Thomas from Hornby
Home › Forums › Beginners questions › Thomas from Hornby
  • #414074
    Zane Crowther
      @zanecrowther67531
      Hi,
      My son's Thomas The Tank Engine from Hornby has a triangular screw on it and I need to open it up. Where I can get a triangular screw driver for it please?
      #9716
      Zane Crowther
        @zanecrowther67531
        #414080
          HI Zane,
          If you google 'security bit set' you can get a whole selection – check the type you need is included. The other option is to file down the end of an allen key.
          Zane Crowther
            @zanecrowther67531
            I didn't think of an Allen Key. I'll try that first before splashing out on a security bit set.
            #414092
            roy entwistle
              @royentwistle24699
              #414101
              Jim Nic
                @jimnic
                ? +1
                #414102
                Brian Oldford
                  @brianoldford70365
                  ? and another.
                  #414107
                  Former Member
                    @formermember53456
                    #414124
                    nigel jones 5
                      @nigeljones5
                      I tried to file down the end of an allen key, all I got was a shorter allen key. I must stress that at no time did it in any way resemble Thomas from Hornby though.
                      #414125
                      John Hinkley
                        @johnhinkley26699
                        One can only imagine that the mention of "security" in Neil's initial response means GCHQ have picked up on it and erased the original post!
                        secret
                        #414128
                        Meunier
                          @meunier
                          Thomas from Hornby is surely a Meccano or OO-related post ?
                          DaveD
                          #414169
                          Perko7
                            @perko7
                            Sounds like he could be a 'contestant' in the Monty Python 'Blackmail' game show laugh
                            #414170
                            RMA
                              @rma
                              Can someone please explain what this thread is all about????
                              #414172
                                Posted by RMA on 14/06/2019 09:43:48:
                                Probably only Fred Karno
                                https://www.model-engineer.co.uk/forums/memberpostings.asp?c=135769
                                Edited By Michael Gilligan on 14/06/2019 09:54:48
                                #414173
                                Journeyman
                                  @journeyman
                                  Top of the thread has gone walkabout! First post is Zane asking where he can get a triangular screwdriver to fix his sons Thomas loco. Neils answer is as above and Zane has replied to say he never thought of a allen key.
                                  I tried to paste it in from a list of Zane's posts but the formatting goes to pot.
                                  Managed to paste it as an image.
                                  Edited By Journeyman on 14/06/2019 10:04:33
                                  #414187
                                  Samsaranda
                                    @samsaranda
                                    Is this a new system for posting questions? We put the answers first then get round to posting the question. 🤪. Dave W
                                    #414188
                                    Daniel
                                      @daniel
                                      Posted by Samsaranda on 14/06/2019 11:18:26:
                                      That would ensure some decent thread shift laughlaugh
                                      #414189
                                        I think Neil may have clicked on something he should not have, I will click it again and then you will be able to see the missing posts.
                                        #414190
                                        roy entwistle
                                          @royentwistle24699
                                          it's all fun isn't it ?
                                          #414249
                                          mark costello 1
                                            @markcostello1
                                            I think Zane should inspect the security set as Mine does not have triangles, better safe than sorry.
                                            #414645
                                            Mohammed Arsath
                                              @mohammedarsath64877
                                              Search in Google surely you will find a store nearby.
                                              #414855
                                              Ian S C
                                                @iansc
                                                I needed a 3 flute screw driver, so I ground the end of a worn out Philips screw driver, then with the Dremel tool ground in the 3 flutes, job done, now I'v got a screw driver that I'll probably never use again.
                                                Ian S C
                                                #415022
                                                Zane Crowther
                                                  @zanecrowther67531
                                                  I didn't have an alley key that was the right size, so I bought an iFixit driver kit in the end. I didn't want to risk stripping the screw head with a flat head screw driver that only went across two of the points.
                                                  Zane
                                                  #415052
                                                    Butterfingers!
