Hot chucks and cold spindles – caution
Home › Forums › General Questions › Hot chucks and cold spindles – caution
Viewing 25 posts - 1 through 25 (of 28 total)
  • #849802
      It’s currently the May ’26 mini heatwave if you happen to be reading this in Jan ’27.
      Your big solid lathe got a bit cooler overnight but your screw on chuck was sitting on the bench in the sun since 6am. If you now screw it onto the spindle you will get a nice shrink fit.
      Likewise the MT3 collet chuck that was under the mill is cooler than the milling machine spindle so again may jam as it warms up.
      Maybe just sit out the day on the north side of the house reading ME&W.
      #849808
      JA
        @ja
        I think you are trying to justify not going out into a hot workshop. Mine is on the south side of the house and its window gets the full afternoon sun. Recently its air temperature at around 6pm has been about 36C. Overnight it cools to around 19C. That is a nice gentle drop in temperature and, I think, the temperature of everything would be similar.
        My justification for no going into a hot workshop is that it is just too hot, for me anyway.
        JA
        Alternatively move the chuck so that it is not in the morning sun. The heat wave will be over by the weekend.
        #849810
        noel shelley
          @noelshelley55608
          In this context Always remove glow plugs from a warm/hot engine but NEVER fit them until the engine is cold ! The difference is staggering – a plug that was on the point of needing drilling out was removed with ease when the engine was hot !  Noel.
          #849811
            …………………..The heat wave will be over by the weekend.
            Then all the parts you have made this week will be too small😉😉😉
            #849822
            Neil A
              @neila
              Like Noel, I always removed spark plugs on my car when the engine was hot, especially on alloy heads, for the very same reason. As he said, the difference is between an easy extraction or the fear of breaking something or stripping a thread. Always refitted when the engine had cooled down a bit.
              As for parts being too small, I remember being told not to hold fuel injector plungers in my hand for too long, otherwise they would no longer fit back into the bore of the mating part until they had cooled down. Always seemed to take longer to cool down than to heat up.
              PS. too hot for me in the shed to do any real work, 36 degrees.
              #849827
                I’ve been out doing real work, luckily the flames are not real although the LED mirrored screen they are on is very realistic. The oak top and lower surround fitted OK Though a bit warm moving the 1900mm long, 100kg fire about on my own let alone the veneered fireproof MDF.
                20260527_104327
                real flame
                #849903
                noel shelley
                  @noelshelley55608
                  That’s very neat Jason !  Noel.
                  #849926
                    Last week my workshop was a bit chilly at 11C. Now it is about 15C. The south facing 2ft granite walls laugh at heatwaves. However I have to spend all day gardening before it rains again.
                    that fire effect is amazing and I was still lighting the living room wood burner until Saturday but in practice barely look at the flames for more than ten seconds an hour, in 1 second glances to check the fuel state.
                    #849931
                      It can be much worse in winter when a cold taper is inserted into a warm socket!
                      #849935
                      DC31k
                        @dc31k
                        It puzzles me a little when I read this.
                        If the chuck goes on and off the spindle when both are at the same temperature (i.e. clearance between parallel register and spindle nose is correct), why will a warm chuck cause a problem? The clearance will be increased; the fit on the threads will be looser.
                        It might be a problem if the spindle was a male taper and the chuck a female taper. Then in its warm state it would go onto the taper further than normal.
                        I cannot see how what you correctly describe for the tapered collet chuck has the same logical connection to a parallel-threaded spindle nose.
                        #849939
                        alecs
                          @alecs
                          The flanks of the thread are an obtuse taper perhaps?
                          #849977
                          Nigel Graham 2
                            @nigelgraham2
                            It puzzles me, too.
                            I can see the case for components like sparking-plugs and injector-pump plungers, but not for a lathe chuck that fits normally when both it and machine are at the same temperature.
                            Does the high-tensile steel of the mandrel have a different coefiicient of expansion to the cast-iron chuck backplate? If so, is the difference so great that the sort of temperature difference here will be significant? Even given that the temperature of the sun-bathing chuck will be higher than that of the air around it.
                            How can a chuck that fits normally, manage to shrink below the register diameter, as would be implied?
                            Once the two masses of metal have equalised the fit should be as normal – but screw-on chucks do have a habit of jamming themselves onto the spindle as if by some Law of Physics yet to be established.
                            What I could understand perhaps, is the mandrel expanding slightly in the much cooler chuck, as heavy use warms the bearings and mandrel. Even then, once both have rested and settled at the same temperature, the chuck should still unscrew – but it likely won’t due to the cutting forces having tightened it. (One reason I dislike interrupted cuts.)
                            #849985
                            Tony Pratt 1
                              @tonypratt1
                              Rest easy Nigel Graham 2 & DC31k, the original post is complete fantasy! The colder lathe spindle will in fact get smaller in diameter the warmer chuck register bore will get bigger so if anything a looser fit but marginal? The mill spindle and collet chuck will get warmer at the same rate so no problem there either over what already exists in using a MT milling spindle taper. I’ve had my say folks, I’ve no more to add.
                              Tony
                              #850010
                              alecs
                                @alecs
                                Tony
                                Exactly! So when the warm and thus enlarged chuck is screwed hard on to the cold shrunken spindle, the two of them then transfer heat and become the same temperature. The cold spindle warms and expands. The warm chuck cools and contracts. Tight fit results.
                                Regarding your last sentence: A man who never changed his mind never thought about anything.
                                #850020
                                Charles Lamont
                                  @charleslamont71117
                                  Hmm. There is clearance in the thread, which has been tightened. As the front flanks of the cooling chuck thread contract on the expanding back flanks of the warming spindle thread, the chuck will be drawn on tighter, but this will be less than the extent to which the cooling chuck contracts axially and the warming spindle expands axially, leaving less pressure, or even a clearance at the register contact face. Or not?
                                  The register diameter is not going to come in to the matter.
                                  #850036
                                  Pete Rimmer
                                    @peterimmer30576
                                    Yeah but it does feel good!
                                    #850109
                                    JA
                                      @ja
                                      The temperature differences between the chuck, register and thread on the spindle will be small, 30C at the most. This, with the transfer of heat, is very unlikely to give removal problems. I can see greater difficulties lifting a hot chuck off the bench. I trust you keep it well oiled!
                                      This weather has wiped me out. Although slightly cooler, today has been the worst.
                                      JA
                                      #850121
                                      Charles Lamont
                                        @charleslamont71117
                                        JA
                                        Why would one oil the bench?
                                        #850124
                                        JA
                                          @ja
                                          Charles
                                          ……………… but I have oiled benches in my time.
                                          JA
                                          #850161
                                          Nigel Graham 2
                                            @nigelgraham2
                                            Alecs –
                                            No: if the chuck fits properly when at the same temperature, it will fit properly when both it and the mandrel have equalised from whatever their respective temperatures when put back together.
                                            The only way a temperature difference might tighten the grip on the chuck is if a cold chuck is screwed tightly onto a hot mandrel, so the nose thread pulls the chuck backwards as the headstock cools.
                                            The opposite to what is described: a hot chuck on a cool spindle.
                                            #850169
                                            alecs
                                              @alecs
                                              On Nigel Graham 2 Said:
                                              Alecs –
                                              That sounds about right.
                                              Although, as pointed out above, will a temperature differential of 30C provide enough thermal expansion to cause sticking? I don’t know. I keep my spindle thread and collar well slathered in anti-seize goo so have never had a stuck chuck in any weather.
                                              #850258
                                              old mart
                                                @oldmart
                                                Possible, but most chucks can be stored underneath the lathe bed or in a tool cupboard.
                                                #850295
                                                martin haysom
                                                  @martinhaysom48469
                                                  Alecs –
                                                  having done quite a lot of shrink fitting in my working life i will say 30c will make no differance
                                                  #853960
                                                  alecs
                                                    @alecs
                                                    I’m sure many model engineers will flock to James’s offer of a cosmetology job. Only the beautiful people here.
                                                    #853984
                                                      Probably the OP is concerned about the “Heat and Freeze” effect that we use when we do want an interference fit.With a 200C vs -18Ctempertaure difference, a 0.001″ interference assembled easily. But with everything at the same temperature, the fit is now permanent.
                                                      So a temperture difference of about 20C is unlikely tp present problems.
                                                      I would much more concerned about my Morse tapers.
                                                      But the sure fire way to be safe, if you are worried, is “Don’t do it!”
