Howardb’s picture shows that the tailstock is in two parts and can be set over relative to the base, but there are no adjusting screws.
We had the same problem with a C1, but used a G cramp as a means of delicate(?) adjustment between upper and lower parts, before fully tightening an Allen screw under the base.
Remove the tailstock and investigate before doing anything that cannot be easily reversed.
You will need an Alignment bar (Bought or shop made with the 4 jaw chuck and probably a steady; or another lathe with a 4 jaw, mag base and DTI)
Howard.
