I have a 3″ LS- so I’m not sure if one is comparing apples with apples.
Anthracite I am not too fond of. It burns very hot and it seems to like a lot of draught, so its either white hot or dying and nowhere in between.
I’ve used various types of steam coal- seems to burn more red than white, but its not so up and down so I find it rather easier to use. But then I have also had some (theoretically) steam coal which clinkered very badly after hard work, and left the grate clogged.
Housecoal they say is pretty good – akin to steam coal. I like the smoke (which you don’t get with anthracite). I didn’t built a steamer to be all eco.
A lot has to do with getting the lumps the right size for the grate in use.
Truth is I doubt it matters, so long as you have grate, blast nozzle and coal sizes, and blower nozzle size set for the stuff one is using, but I prefer steam coal, or failing that a mix of anthracite and steam coal, using plum sized lumps.
Ask at the club, see what they suggest for such a loco and then give that a go – see whatt happens? At the end of the day its a steam engine – ain’t that critical and ain’t exactly rocket science.
Edited By mgj on 30/12/2011 23:00:55
