Door stay help
Door stay help
Home › Forums › The Tea Room › Door stay help
  • #36020
    AJW
      @ajw
      #489946
      AJW
        @ajw
        We had a couple of uPVC doors fitted about 9 months ago. There was an option of a door stay unit that fits to the top of the door and has an adjustment screw fitted to create friction in the door stays operation which we have found quite useful as the door can be left part open and resisting wind gusts.
        I have now found that the friction adjustment is all taken up and no more friction adjustment! All worn out in 9 months.
        Removing the unit from the door it is of a very poor design so I dug out a lump of brass in the hope I can make something longer lasting but before I attempt a redesign I thought I would ask has anyone had experience of uPVC door stays that work and more importantly – keep working!
        Alan
        #489957
          Is it something like moulded nylon – a bit flexible? Brass might be too hard to get adjusted unless there is room for a spring. Maybe tufnot.
          #489964
          Circlip
            @circlip
            Door furniture for plastics were never meant to be a "Partial" thing, Door is either closed or fully open, design was to stop door opening greater than 90deg. saving tears if you inadvertently let go while opening it in a wind. French doors??
            Regards Ian
            Edited By Circlip on 10/08/2020 12:28:43
            #489969
            Jim Young 2
              @jimyoung2
              Many and various designs on eBay for between £5 and £10. Can you just replace the friction pad perhaps?
              #489976
              AJW
                @ajw
                Thanks for replies! Yes the assembly uses a moulded nylon section for applying friction and it works well but it slides inside the extruded aluminium section that fits the door channel.
                Unfortunately the friction wears out the nylon piece. I have seen the same design from various outlets from less than £4 but I know they won't last!
                Even found a review of door stays where this design came up trump's although it's obviously not been tested over a longer period as it would wear itself out.
                Think I need to re design the idea.
                Alan
                #489978
                Nick Wheeler
                  @nickwheeler
                  Posted by Circlip on 10/08/2020 12:27:28:
                  it's also intended to prevent the door and mechanism from damage by slamming shut. The stay will slow it down.
                  #489979
                  Phil H1
                    @philh196021
                    Not quite what you have described but we have two quite wide French type doors and we use two simple brass hook and loop arrangements. The hook is attached to the wall and the loops on the bottom of the door frames. They hold the doors wide open and there is no problem with the wind.
                    #489981
                    pgk pgk
                      @pgkpgk17461
                      I have the same arrangement on my UPVC patio doors..totally useless in any breeze. My solution was to add hooks and eyes from outside wall to door at the bottom… simple and guaranteed.
                      pgk
                      #489995
                      Danny M2Z
                        @dannym2z
                        I just use a rubber wedge under the door. Open door, kick the wedge in place.
                        #490003
                        Clive Brown 1
                          @clivebrown1
                          Our conservatory door suffers from the wind when left open in hot weather. A friction stay was no help. An outside step made a door stop diificult to devise. Solution this year has been a short length of rope, loop in each end to connect the door handle to the nearby garden bench. Takes seconds to deploy. Success!
                          #490025
                          MadMike
                            @madmike
                            Nine months old? get the crew back that fitted it. Do not alter anything until they have sorted it as they will simply accuse you of tampering.
                            #490026
                            Sam Longley 1
                              @samlongley1
                              #490028
                              Cornish Jack
                                @cornishjack
                                Sam has it – we have two fitted to our french windows and they JUST WORK, – and have done untended for 6 years so far. Have just ordered another for the scullery door. Available in 8" and 12". We use the 12" to cope with the outside step.
                                rgds
                                Bill
                                #490031
                                AJW
                                  @ajw
                                  Yes, only 9 months usage! Disgusting, and I am sure they would be replaced but I would only get another 9 months use because they just wear out!
                                  As you say I could fit one of the 'door holder open' type stays but the beauty of the original (albeit short term!) is the ability to leave the doors anywhere between ajar and fully open.
                                  Alan
                                  #490044
                                  larry phelan 1
                                    @larryphelan1
                                    My Granny used to use a spare brick to hold the backdoor open, but I suppose that would be out of fashion these days ?cheeky
                                    #490080
                                    Perko7
                                      @perko7
                                      Would replacing the nylon with a stiff felt pad (the type used for putting under chair legs) be a potentially more long-lasting option?
                                      #490088
                                      john carruthers
                                        @johncarruthers46255
                                        We would fit 'restrictor stays' as a safety option, mainly on tilt&turn windows on upper floors to avoid people falling through. They are a simple toothed bar that clips onto a stud.
                                        They can be fitted to doors and would give some adjustment to how wide it opens.
                                        Or, how about a damper style restrictor as used on caravans, boats, etc ?
                                        Edited By john carruthers on 11/08/2020 08:56:27
                                        #490098
                                        AJW
                                          @ajw
                                          The felt idea sounds like it would offer better long term operation, I will certainly look that idea. The only real restriction is that any of the friction components need to operate in the extruded aluminium channel fitted into the door edge shape, and it is just over 1/2 in wide!
                                          Our old wooden doors had a friction device incorporating a max opening position. This was screwed to door and frame with the 'hinge' between both parts having the friction components fitted a bit like the old suspension dampers used on old Bentley's etc. Worked a treat and as the cork components wore they could be re adjusted with a wing nut.
                                          Not the sort of thing that is suitable for a plastic door/frame though.
                                          John, you refer to a damper/restrictor – got anymore info?
                                          Alan
                                          #490194
                                          AJW
                                            @ajw
                                            Well I woke up with the bit between my teeth this morning determined to improve the stays!
                                            Found myself a piece of self adhesive felt which when compressed was about .035 thou thick, a lump of steel to machine into a 'T' shape to fit the alloy channel. Had to pop round local screw supplier for some grub screw's and csk jobbies.
                                            Basically spent all day developing them but am really pleased with the results. I have two grub screws which expand the T section with the felt attached to adjust the friction within the channel.
                                            The original design, while obviously cheap is of very poor design and of very limited lifespan, how can they sell such a poor product?
                                            Alan
                                            #490216
                                            Sam Longley 1
                                              @samlongley1
                                              Posted by AJW on 11/08/2020 21:33:01:
                                              Well you bought one for a startwinkfrownsurprise
                                              Edited By Sam Longley 1 on 12/08/2020 06:51:43
                                              #490222
                                              AJW
                                                @ajw
                                                Guilty as charged M'lord! In my defence I plead ignorance as I asked for doors to be supplied with stays.
                                                I'm waiting for the 'how did we do' for feedback!
                                                Alan
                                                #490223
                                                pgk pgk
                                                  @pgkpgk17461
                                                  A quck look-up cheat tells me that a 40mph wind gust exerts 6.4lbs/sqr foot pressure. Assuming a half pair of french doors 2ft x 6.5ft = 83+lbs pressure. Thst's a lot to control with a small contact sliding pad in a groove.
                                                  (I chose 40mph gust 'cos they are fairly common in my valley even on 15mph wind days and far be it for my OH to actually hook the door back…I have to get there first)
                                                  pgk
                                                  #490253
                                                  AJW
                                                    @ajw
                                                    Agree, less than ideal but better than nothing.
                                                    Alan
                                                    #490299
                                                    john carruthers
                                                      This sort of thing?
                                                      I've fitted many to boats, caravans, greenhouses etc….
                                                      toolstation stay
