Annealing 316 stainless steel
Home › Forums › Hints And Tips for model engineers › Annealing 316 stainless steel
  • #30460
    michael howarth 1
      @michaelhowarth1
      #130154
      michael howarth 1
        @michaelhowarth1
        Can anyone assist me regarding whether a 1/8" 316 stainless steel tube (id-3/32" ) can or should be annealed before bending is attempted? It is to be used as a superheated steam pipe on a small gauge loco and will require a couple of bendy bits in the smokebox.
        Mick
        Edited By JasonB on 19/09/2013 17:32:57
        #130166
        jason udall
          @jasonudall57142
          I am given to understand 3xx series stainless is “not amenable to heat treatment”…
          But I have would coils in that section with out filling or forming springs down to 1″ id….verrry tough but no sign of wall collapse…makes fair spring….
          #130179
          David Jupp
            @davidjupp51506
            You could anneal it to remove/reduce the effects of work hardening – the 300 series work harden like crazy. Rapid cooling (water quench) is desirable after annealing (which sounds odd when you are used to Q+T alloy steels).
            #130188
            Anonymous
              As Jason says 316 cannot be hardened by heat treatment, but it can be annealed. So it would seem sensible to do so before bending. However, you will need to heat it to a bit over 1040°C to do so.
              #130227
              michael howarth 1
                @michaelhowarth1
                Thanks for the input gents, the quenching is particularly interesting as is the temperature required.
                Mick
                #130268
                Sub Mandrel
                  @submandrel
                  When starting out I was sold some 'silver steel' at a car boot. It turned out to be a decent free-cutting stainless, but I had fun trying to harden it.
                  michael howarth 1
                    @michaelhowarth1
                    My 316 1/8" tubing arrived today and the part was made. I was most surprised to find that it was in an annealed condition already as it bent into shape very easily, not much different to copper. Thanks for all the advice anyway which I am sure will be useful in the future.
                    Mick
