Engineering Oddities
Home › Forums › Hints And Tips for model engineers › Engineering Oddities
  • #122681
    Sub Mandrel
      @submandrel
      The other day I was reading an old (but not THAT old) engineering book, and for polishing cast iron it suggested using a walrus skin buff.
      Google can't find any suppliers!
      I wonder what other strange tips folks have come across over the years.
      Sub Mandrel
        @submandrel
        Strange Tales from the Workshop
        #122684
          Also mentioed here
          Sub Mandrel
            @submandrel
            Walruses get on better with woodworkers than metalworkers. Now we know why.
              Here is an interesting visit to "The Grinding Museum" at Solingen.
              Ady1
                @ady1
                Whale oil is good for hardening and tempering
                1.kill a whale
                2.Squeeze out any oily bits
                3.plunge metal rod into oil when cherry red
                #122719
                Danny M2Z
                  @dannym2z
                  G'day.
                  While sperm whale oil is still preferred by watchmakers for oiling delicate bearings, I still use tallow for checking piston/liner fits in model sized engines. What makes it a bit different from the U.K. is that I hunt the (feral) pigs with a .444 Marlin lever action and the tallow is rendered from the fat. Nothing is wasted as my neighbour has a smoker.
                  Regards from the land of the kangaroo
                  Cu Later * Danny M *
                  #122730
                  Martin Kyte
                    @martinkyte99762
                    Slightly off topic but not much. Have you not heard of razer strop fungus for putting and edge on your cut throat? Technically known as Piptoporus betulinus.
                    Martin
                    #122747
                    Ennech
                      @ennech
                      in the works her I was apprenticed, we had a foundry that used Loam (pronounced loom) moulding for the stators of large electric generators about 30 feet in diameter. In order to produce the sand mould in the foundry floor the circular design was swept by means of a shaped board on an arm around a centre post. There were either of two ingredients used to bind the sand together, spent hops or horse dung. I understand that the foundrymen preferred the horse dung!
                      #122748
                      Clive Hartland
                        @clivehartland94829
                        I had some watch oil that was reputed to have been extracted form the jaws of a Porpoise! It certainly did not 'creep' like some oils do. Later I bought some synthetic oil that went every where and soon dried out from the bearing.
                        The Whale oil, while doing my apprenticeship we had a Whale oil bath and I used it to quench some HHS lathe tools I made and boy were they hard.
                        #122789
                        Robbo
                          @robbo
                          Lubricants for thread cutting listed in my much-prized set of BA taps and dies, by Fredk. Bates & Co, include:
                          for copper – milk, for bronze – rape oil, for tool steel – rape oil, lard, or whale oil, for stainless steel – turpentine and white lead . Paraffin was also recommended a lot.
                          Nowadays I just have a can of RIDGID Threading Oil for anything that needs a lubricant.
                          Phil
                          #122793
                          Robert Dodds
                            @robertdodds43397
                            Hi,
                            Further to Robbo's observations Dad used to swear by "Neatsfoot Oil" for tapping out tough steel. Wikipedia tells us its made from rendering shin bones from cattle, is good for softening hard leather so may be useful for dressing walrus hide and that its also good for machining aluminium.
                            Modern versions also blend in rape and soya oil
                            Bob D
                            #122797
                            Kevin F
                              @kevinf
                              When I was an apprentice there was a lot of talk in the machine shop about ' nats cock ' I soon learnt that a Nats cock
                              was a thousand of an inch laugh
                              #122808
                              Danny M2Z
                                @dannym2z
                                G'day
                                The parlance of undocumented units is vast. Although they are not real units most people seem to get the gist of what one is trying to say, for example if one was told to take-off;
                                A tad
                                A smidgin
                                A knat's whisker
                                A poofteenth
                                A mickhair
                                A sh*tload
                                …etc
                                of material, then the intent to take of a little bit more has been communicated.
                                Down here (in the colonies) Neatsfoot Oil is still available for leather dressing a 'Sam Browne' belt etc. But you have to earn the right to wear such a belt to learn where to obtain the stuff.
                                C'est la vie
                                #122817
                                Robbo
                                  @robbo
                                  I'd forgotten about Neatsfoot oil. My wife uses it to soften leather when making handbags etc.
                                  (Not for making the bondage gear more comfortable, though it would do for that!)
                                  Available over the Internet – what isn't these days
                                  Phil
                                  #122825
                                  jason udall
                                    @jasonudall57142
                                    What is a Neat . And why would its feet need oiling?
                                    #122829
                                    Ian S C
                                      @iansc
                                      Here's one from one of my old books: "Soldering Without Heat":- Brass filings 2 oz, steel filings 2 ox, fluoric acid 1/4 oz. Put the filings in the acid, and apply the solution to the parts to be soldered, after cleaning the parts in contact; then dress together. Keep the fluoric acid in lead or earthen vessels.
                                      Ian S C
                                      #122854
                                      Robert Dodds
                                        @robertdodds43397
                                        Hi.
                                        I know that they are probably onomatopoeic, but can anyone come up with definitive photos of a Timping hammer and a Spelching hammer, terms used in the mid fifties in the Lancashire area?
                                        Bob D
                                        #122856
                                          Bob,
                                          I would guess that Timping is a dialect alternative to Tamping
                                          Spelching has a woodworking definition, but I can't quite see the connection with hammers.
                                          Rik Shaw
                                            @rikshaw
                                            I like the way they used to use wood (lignum vitae) for ships prop shafts bearings , powdered bone for case hardening steel, turds for tanning leather.etc. etc. Paying lip service to these old methods I regularly imbibe embalming fluid in the form of Scotlands finest and trust that unlike Freddy Mercury I WILL want to live for ever. —- Rik
                                            #122859
                                            Sub Mandrel
                                              @submandrel
                                              Investigating violin repairing, I was struck how hide glue appears to be so superior to synthetic adhesives.
                                                Posted by Stub Mandrel on 21/06/2013 21:05:14:
                                                And, for repairing books, an adhesive made from the swim-bladder of the Sturgeon is still unsurpassed.
                                                I was recently studying a book by Albrectht Dürer, which has a "paste-over" correction on one of the diagrams. There is absolutely no sign of lifting, embrittlement, or discolouration … The book was printed, and the correction applied, in 1525.
                                                MICHAEL WILLIAMS
                                                  @michaelwilliams41215
                                                  (1) Hanging on a wall at a very well known company there was once a certficate proclaiming :
                                                  ' This is to certify that all drinking water provided at this establishment has been passed by the management '
                                                  (2) Grinders always go mad :
                                                  The same well known company had several canteens including one very large one used by mainly shop floor employees . On one occassion as a very young man I was in there when a man in his forties suddenly started running erratically around the tables and babbling incoherently . There was a table of old hands nearby and one of them looked round to see what the commotion was . Turning back to his friends he just said knowingly the one word ' grinder ' – at which his friends nodded sagely and continued with their meal .
                                                  Apparently it was quite a common occurrence for workers in the precision grinding section to ' have a wobbler ' .
                                                  It's actually not hard to see why a man doing noisy , nerve jangling and very demanding work on high value components all day could become a bit disturbed .
                                                  I never heard what happened to the poor grinder .
                                                  MikeW
                                                  #122875
                                                    Posted by Rik Shaw on 21/06/2013 20:01:59:
                                                    I like the way they used to use wood (lignum vitae) for ships prop shafts bearings… , — Rik
                                                    They still do. Submarines still use lignum vitae for the stern tube bearing, quiet, long lasting and lubricated by sea water. Not sure about surface vessels these days though.
                                                    And neatsfoot oil — I always did wonder what happend to all those poor neats hopping around with no feet.
                                                    When I was an apprentice, an old merchant navy ex-stoker told me to pee on your hands if you get blisters from shovelling clinker, or from pulling a cleaning brush through a million boiler tubes. It did not seem to me that it made much difference though. He did teach me how to repack a leaking valve using a string from the boilerhouse floor mop for packing. That one worked ok.
                                                    And my old man was so tight he used to use treacle or Golden Syrup for gasket cement on his motorbike, and sealed leaking intake manifolds by applying treacle to the outside of the manifold with the engine running, and then throw a hand full of dust over it while revving the engine "to suck it in and get a good seal".
                                                    #122877
                                                    jason udall
                                                      @jasonudall57142
                                                      Jack& jill treacle and brown paper?
