More Info
More Info
Home › Forums › General Questions › More Info
Viewing 25 posts - 1 through 25 (of 26 total)
  • #183712
    Harry Wilkes
      @harrywilkes58467
      Hi Guy's a friend picked this up a would like a little info on it, can anyone throw some light on it please.
      Cheers H
      #23777
      Harry Wilkes
        @harrywilkes58467
        #183713
        Les Jones 1
          @lesjones1
          Hi Harry,
          It looks like a centrifugal water pump to me. I have no idea of the manufacturer.
          Les.
          #183714
          roy entwistle
            @royentwistle24699
            It looks like a centrefugal pump       Stuart Turner perhaps
            Edited By roy entwistle on 19/03/2015 09:04:25
            #183715
            Nick_G
              @nick_g
              Looks to me as if it's some kind of centrifugal water or other liquid circulating pump.
              What it's originally intended for I can unfortunately be of no help to you with.
              Nick
              #183716
              Nick_G
                @nick_g
                Next time the 'circ pump' on your central heating goes you could replace it with that. winkwink
                Nick
                #183717
                  Centrifugal pump but its not a Stuart one as the feet were not part of the main pump body
                  #183718
                    Harry,
                    Centrifugal Pump … Looks too nicely made to be commercial, so Stuart Turner or similar origin seems likely.
                    These notes may be of interest.
                    Edit: just seen Jason's reply …
                    Edited By Michael Gilligan on 19/03/2015 09:07:24
                    #183721
                    Ian S C
                      @iansc
                      Harry, what size is it?
                      Ian S C
                      #183817
                      Harry Wilkes
                        @harrywilkes58467
                        Thanks to all for the replies and Ian I'll get some dimensions
                        Cheers H
                        #183821
                        Ian P
                          @ianp
                          Harry
                          What colour is the one that you want identifying?
                          Ian P
                          #183831
                          Johnboy25
                            @johnboy25
                            It's a Stuart centrifugal pump as shown in my 1940 – 1941 Stuart model catalogue. Page 36. I've always been under the impression that WW2 was gripping Europe. Did Stuart help with the war effort? Just a thought.
                            However… I've taken a pickie but don't know how to insert it with the text? I'm sure someone will tell me or point me to the right thread! Still – I've just come back from an evening out with my 'last of the summer wine' pals and the alcohol doesn't help!
                            Johnboy25
                              @johnboy25
                              Stuart Centrifugal Pump
                              #183835
                              Johnboy25
                                @johnboy25
                                Done it!
                                #183841
                                Nicholas Farr
                                  @nicholasfarr14254
                                  Hi, same type of pump as shown by Johnboy25, but a different design. In Harry's picture, it is possible to strip down the pump leaving all the pipework intact and the bearings can be worked on, on the bench, and the outlet is opposite hand. With the Stuart design you would have to at least disturb the inlet pipework to get to the impeller to clean out debris or remove the bearings for maintenance. They will both do much the same job though.
                                  I've worked on much larger ones of both types and the one in Harry's picture are much more easy to work on. I do realise these are only small, but if you don't have to disturb the pipework, so much the better.
                                  Regards Nick.
                                  Edited By Nicholas Farr on 20/03/2015 01:29:36
                                  #183856
                                    Looks like Stuarts may have changed the design at some time, this is the one from my 80s catalogue which has a different foot and flange mounting for the outlet, they do call it teh No 2 pump so could Harrys be a No 1?
                                    #183857
                                    John Olsen
                                      @johnolsen79199
                                      Stuart did indeed help with the war effort. They made a little steam powered generating set that was used to power clandestine radios. I would also expect that like most manufacturing plants, they would have been going flat out at making whatever was needed that fitted their capabilities.
                                      Apart from that, I believe that at one time they were making quite a lot of pumps in the full size world. I think they divested the model side at some point, or maybe vice versa.
                                      Harry Wilkes
                                        @harrywilkes58467
                                        Many thanks to all for replies and info.
                                        Cheers H
                                        #183861
                                          Some useful images on this thread.
                                          P.S. … Nice 'Timeline' here, with a great picture at 1906
                                          Edited By Michael Gilligan on 20/03/2015 08:12:39
                                          #183872
                                          Gordon W
                                            @gordonw
                                            I've always assumed that Stuarts models was the same co. as the Stuart who made full size pumps, maybe not. I have a Stuart piston water pump, used on my well. the parts list shows an extra was a sleeve and piston to convert to a boiler pump, about 1" dia.
                                            #183873
                                            IanT
                                              @iant
                                              I think they were Gordon – I seem to remember seeing both pumps and casting kits in their shop window when they were still based in Henley-on-Thames.
                                              IanT
                                              #183875
                                              V8Eng
                                                @v8eng
                                                Stuart turner have a very long and interesting history in Henley, making: model engines, pumps and even motorcycles.
                                                I've put a link here to their history.
                                                Edited By V8Eng on 20/03/2015 09:39:01
                                                #183922
                                                Harry Wilkes
                                                  @harrywilkes58467
                                                  Posted by V8Eng on 20/03/2015 09:36:50:
                                                  yes smiley
                                                  #183924
                                                  DMB
                                                    @dmb
                                                    IIRC, Model Engineer ran a short article or 2 on the subject of a small vertical steam boiler powered generating set for the use of agents transmitting clandestine radio messages back to the UK during the war.
                                                      I recall the set was designed by Ian Bradley, and used a Stuart Sirus.
