Posted by Phillip Allen on 31/07/2019 11:55:46:
Michael, I want to make an array of small lights. Are you telling me that Al will not be suitable for running a low voltage current? I know it is used in HT power cables. I can swap over to Cu instead, no big deal except cost.
Thanks,
Phillip
Yes, Phillip … I'm afraid that is what I am telling you
The first thing that fresh Aluminium does [within seconds] when exposed to the Air is cover itself with a layer of Aluminium Oxide … Which is not only very hard, but also a very good insulator.
If you intend using the Edison fitting in the normal manner, then I would strongly advise against using Aluminium.
The good news is … If you are prepared to use Copper [or anything more precious], you could probably electroform the sockets; then fix them into holes in a plate.
