Myford gravity cutting fluid delivery?
Home › Forums › Workshop Tools and Tooling › Myford gravity cutting fluid delivery?
  • #315890
    Hillclimber
      @hillclimber
      I stumbled onto this picture of an S7 fitted with what appears to be a gravity-feed cutting fluid delivery system? That looks like a drip-oiler cup fixed to a partly-hollow post mounted on the cross-slide?
      Just wondering if any of you have experimented with similar? And might share pictures?
      Cheers, Colin
      #18647
      Hillclimber
        @hillclimber
        #315893
        John Haine
          @johnhaine32865
          Interesting idea, looks like it would soon run out.
          #315933
          Brian Sweeting 2
            @briansweeting2
            Not a new idea but a good drip oiler.
            See Emmas' igram picture here ..
            Robbo
              @robbo
              Colin
              Int 'tholden days it was common to have a shelf behind and above the lathe. Put a gallon (4.5 litre) can with a flexible tube and nozzle on the end from can to lathe. Simple tap on nozzle (eg motorbike fuel tap) and let it drip away.
              A bucket under the swarf tray outlet collected the run-off coolant which was returned to the can.
              I'll try and find a picture.
              #315974
              the artfull-codger
                @theartfull-codger
                I've had a 1 gal plastic tank on a shelf above my lathe for years & the usual pipe down to the tool with a valve, it provides all the coolant you need, I collect the coolant in the tray outlet & filter it then back in the "header tank",I wouldn't bother with all the fancy (& sometimes expensive) ideas for a pumped system,I don't bother with the myford, just use a brush & oilcan but only on the student, which does 90% of my turning.
                #315975
                the artfull-codger
                  @theartfull-codger
                  Haha, you beat me to it Robbo whilst I was typing!! a man after my own heart!!
                  #315985
                  Roderick Jenkins
                    @roderickjenkins93242
                    From Tubal Cain's "Simple Workshop Devices":
                    Cheers,
                    Rod
                    #316040
                    Hillclimber
                      @hillclimber
                      Posted by the artfull-codger on 08/09/2017 19:32:40:
                      And indeed, I spent 80p at Ikea yesterday acquiring a handy plastic bottle that has a trigger spray pump with adjustable nozzle….
                      #316072
                      Juddy
                        @juddy
                        I use one of these small pumps in a builders bucket positioned under the lathe, powered by an old router plug in 12v adaptor.
                        with a length hose to one of these, and a return hose to the bucket from the swarf tray.
                        works really well and is capable of supplying more than enough coolant.
                        I drop the pump into a fine mesh sleeve to protect it from metal particles, and dangle a magnet into the bucket now and then to collect any settled swarf.
                        Has been working fine for the last year or so, – now I've said that it will probably pack up.
                        #316077
                        Hillclimber
                          @hillclimber
                          *old sock*
                          Posted by Juddy on 09/09/2017 10:38:30:
